TMNT
7,074CR
My turtles game now has an issue where the sprites just keep scrolling looping
Video here of the issue ..
Any help appreciated:)
Passes mask rom check
6,898CR
Sneaky feeling it will be one of the customs , 90% of the time its that on konami boards.
They are my favourite board to work on (i hope you can read the sarcasm in that !)
7,074CR
Yeh I am following your Tmnt thread closely .. ❤️. 🤣🙌.
You know it .. I hope my board can be fixed though in all seriousness…
I just hope it can be -
7,074CR
I have pulled this from Arcade projects
This could be caused by a faulty mask rom, or any one of a million other logic ic's being faulty such as a mux or the static ram. Depending on the condition of the board, it could even be a broken trace / via as these Konami boards suffer quite badly from corrosion.
6,898CR
Yeh you go down the line (or i do) in this order :-
1) check and verify rom
2) probe entire circuit ttl, ram , rom for floating pins.
3) check and verify ram
4) checkball ttl in circuit.
If all pass its the customs. Problem with yours is its passing the tests !!! Hence me saying large chance its customs.
As the article says no mater how good the condition of board you can get tracks that break. I had several on my Simpsons and one was broken under the custom (threw me for a while).
7,074CR
Hiding under the chip!
Little basterd …
Hhhhmmmm. I missed a good desolder tool recently .. but I wouldn’t want to touch this one.. need to start on some less precious’s
6,898CR
Yeh and konami boards are ( in my opinion ) hard to work on and a pain in the arse getting chips of.
If your just starting with solderjng / desoldering give me a shout i have shed loads of bootleg boards you can practice and fix or use for spares. All at the right price as i need to slim down !
7,074CR
I thank you most sincerely but I do have a stack of such boards my self 🤣🤣🤣🍻. And it’s getting bigger
I just need a good desolder tool right now .. mist one right in my town as well because I been away..
But I have just spotted a Suspect trace .
Going to check it out now ..
6,898CR
Prety much but dont probe the chip as they are so close you will short the pins for sure, Find where they go and probe there. Have a look at the CPP and it will tell you what chip does what , Its what I would do as I always forget. 2 work in unison with each other, so its one of 2.
7,074CR
CPP?
