4 slot neo geo repair
6,491CR
Repaired the bad traces
And now get
But now I’m stuck at
I have now left all the contacts
Connections with deoxit on ..
Cleaned the pcb up just a quick go over
Will try again tomo after cleaning all the cartridge slots etc ..
any advice welcome ?
I only took psu up to 5.18 v I don’t think it’s a voltage thing could it just be bad dirty / oxadized contacts ?
6,491CR
This one now works 🤪
I’m starting to think as this one is smaller 4 slot type it’s getting 5.2v
From my psu ..
The other knocks the psu back to 4.8 is my psu maxed out ..
Could it be a power thing
6,491CR
I got two mvH mv4.
Same model 1 with power connector
And 1 bottom only board without it ?
Do I need that to power the top pcb ?
I have meterd the side 32 pin inter connectors no voltage so my top pcb im saying needs that voltage it ain’t getting and that why my board ain’t booting into games ?
Joboopoot
68CR
What's the rating of your power supply? As fully loaded with carts the mv4 can pull 6 amps your current might not be meeting demand. Also don't go higher than 5.2 volts, as pretty sure the TTL chips have a max of 5.25 volts.
6,491CR
Not gone over 5.2v
I really want to find the issue …
I’m thinking it isn’t getting voltage to the top board :.
I need to find out where all the voltage pins are on the 32 pin connectors ?
Test for correct voltages on top pcb
This is my next idea
