Arcadia Super Select System
92 (99%)
5,289CR
Has anyone hunted down Lee M. Robertson?
I had a quick look on Google and LinkedIn but can't find any trace of him.
RMCretro
20CR
Thanks for posting this. It is good to see what is supposed to happen on boot.
Does your A500 board have any visible modifications, such as jumer wires or missing ROM chip ?.
I ask because I have a backplane board and cartridge boards that I plugged into a stock A500 board. Mine just boots to the usual kickstart screen. I've always wondered if there is anything I need to do to get it to boot from the expansion board ROM.
It seems to be a bog standard board, there is some patch work but I think that's just because it's an early Rev3. I tell you what, I'll plug another A500 board into it later today and let you know if it boots up with a known vanilla board.
RMCretro
20CR
I think it’s a custom kickstart Rom, not sure - think I saw that when studying the Mame files
It's a regular KS, 1.2 in this case. Here's some info from Toni (WinUAE dev) via h0ffman
"it is basically nothing else than ROM board inserted in side expansion slot. "BIOS" ROM appears at $f00000+ and it has resident structure that normal KS ROM detects and executes. "GAME" ROM appears at $800000+. There is (battery backed?) NVRAM at $800000+$1fc000, size 4k. And finally, multi-game cart has multiple ROMs, selected by writing to $800000+$1ffffe.w. Parallel port connects to coin slots and service/start1/start2 buttons."
h0ff is looking into the feasibility of adapting his Cecconoid game into ROM for us to flash and get a new game on the system.
RMCretro
20CR
Right on closer inspection that won't work. The Arcadia Amiga is an NTSC model. Some A500's have an Agnus that can be switched to NTSC with a little mod so perhaps if you try that on yours it will boot, I'd be interested to know.
cliff_poole
1,069CR
Thanks very much for that. I'll have to dig it out again. My notes say that the board I used was rev 6A , so much newer. I do also have the single game Leaderboard, so could try that too.
I have a feeling mine is faulty, otherwise why would someone have removed it from all the framework. If memory serves, I poked around a bit and found too many floating signals, coupled with all the PALs, made me give up.
Have you seen the version of Nemesis someone created for the Amiga recently ?. Datastorm would be great in a cabinet too.
RMCretro
20CR
I'll check that out thanks! We did find our board was oddly "soft", like part of a regular PCB manufacturing process had been skipped and there wasn't a tough top layer on it. This resulted in 3 traces being easily damaged in transit, so if yours is the same it's worth checking over for any dings.
DaveR
305CR
This is the Arcadia stuff that I was talking about , i sent u some rom boards for the side of an a500.
You see the Github on there, there is a way of encoding the ROMs... I didn't get that far but I understand Aargh might be unencrypted.
The game I wanted to transfer over was the new version of Bubble Bobble.... its Tiny Bobble and is on a Github i think. i could be wrong, I thought that be the perfect game to have on there and its only a small file size and developers are available.
RMCretro
20CR
I'd be interested in seeing this running.
I've had a backplane and game boards for a long time. When I tried pairing it with an A500 board, I couldn't get it to boot. I'm still not sure if it is faulty or if I just didn't have it wired up properly.
I do remember the machines being advertised in Ace magazine back in the day. Great late 80's magazine !. It covered all home computers, and they reviewed arcade games too.
A bit more info for you as I've been working on it more. I found that if you replace the Rev3 NTSC Amiga 500 with a Rev5 PAL A500 it works absolutely fine, I can't see any speed or display differences it just works. If I had Kickstart 1.3 in it would just boot to the Kickstart screen but as soon as I put KS 1.2 in the Arcadia booted normally, so that seems to be key. Also make sure you have the additional 12v going into the Arcadia expansion board.
4,382CR
I was playing Ninja Mission the other day on my Amiga, first time I'd got the game working. I often wish I'd bit on one years back which sold for £50/60 complete working machine but I only really interested in Ninja Mission game so didn't bother
1,703CR
Remember rinsing this game at home also , 87/88 was a great time for Ninja titles I miss it. Going to fire up Shadow warriors tonight on the Goliath.
4,382CR
I never had it on ST or Amiga back then, remember seeing Road Runner on ST in local Mays shop and then wanting ST but never got it when I had the computer
When you see the Amiga version on the Arcadia Select System in the Zzap Day At The Arcades supplement suddenly the C64 version I was playing wasn't good enough lol so it's nice to play it on the Amiga now
Did buy the Arcadia board setup without games and was trying to get some games and a cab for it but gave up and sold it like an idiot, seems most things I sold I should have kept lol but i've got plenty of cool stuff still
