DisplayPort v1.4a or HDMI v2.1?
big10p
Coins detected in pocket!
5,198CR
Just got a wizzy new monitor that supports the latest HDMI and DisplayPort versions, but my aging gfx card only supports v1.4a for DisplayPort.
Haven't set the monitor up yet, but wondering which connection is likely to be best? Not using multi monitor setup, so daisy chaining is irrelevant.
eliotcole
686CR
DP1.4 will involve compression, I think, at higher quality methods ... ...
HDMI 2.1 will have native capabilities that MIGHT outstrip that ... ... but ... again ... unsure ...
DP2... er ... something ... has all the goodness ...
Anyway ... I think that if you're wanting to keep yourself able to use other equipment ... then ... think about staying on HDMI ... because if you end up putting an AVR in that chain to have some cool 7.1 or Atmos/DTS-X like surround ... then ... HDMI will likely be your buddy, there, and you'll have set yourself up in advance.
That's not to say that DP cannot handle that stuff, it is just that almost no equipment other than PCs and a few industrial/commercial products use DP.
All that being said ... I'm like @xMasterPx ... DP all the way. ... 😅 ... plus ... it's just a nicer connector, y'know?
