Plug in the usb drive to any usb port in rpi device. Press start on controller to open OPTIONS menu. Go to STORAGE. In STORAGE menu select USB1 to mount the usb drive. That will create folder structure on the usb drive. Unplug the usb drive and plug it to your PC. Find roms folder and put the roms to correct folders.Hi all,
Im new to this raspberry pi,I’ve got this connected to a rgb pi jamma and I’ve flashed the rgb pi os4 to the card,it boots ok but how do I put arcade roms to it?im not using wifi but I want to use a usb drive.
Look right low corner of the screen, it says P.1/2 (page 1 of 2) Storage will be on Page 2. I guess.Hi, there's no storage select?View attachment 46969
Maybe L or R button on the controller?I've tried that but no luck.
I've already had a look but no option on storage.Have a look in the system menu.
I'm using an arcade cab with arcade controls.Maybe L or R button on the controller?
edit your buttons and use Button 3 and 6 as R1 and L1 then try to change page in OPTIONS using this buttonsI'm using an arcade cab with arcade controls.
The rgb pi image I have is official.The best thing to do would be to getting official RGB-Pi image.
That's very confusing, my cab has six buttons.edit your buttons and use Button 3 and 6 as R1 and L1 then try to change page in OPTIONS using this buttons
