Rgb pi
sukhbir
35 (100%)
1,321CR
Hi all,
Im new to this raspberry pi,I’ve got this connected to a rgb pi jamma and I’ve flashed the rgb pi os4 to the card,it boots ok but how do I put arcade roms to it?im not using wifi but I want to use a usb drive.
HDemon
341CR
Hi all,
Plug in the usb drive to any usb port in rpi device. Press start on controller to open OPTIONS menu. Go to STORAGE. In STORAGE menu select USB1 to mount the usb drive. That will create folder structure on the usb drive. Unplug the usb drive and plug it to your PC. Find roms folder and put the roms to correct folders.
HDemon
341CR
After you have your roms on the usb, plug it back to rpi device. You need to mount the drive again. Just repeat the process from before. When the storage device is mounted, go back to OPTIONS menu and find SCAN GAMES to scan your usb device for games.
