Problem Sanwa 29e31s green
jerryspaghetti
32 (100%)
1,796CR
So I did some more testing and tried the following:
Replaced entire neck card with one from a spare chassis and exact same problem
Replaced the entire chassis with the spare and exact same problem
Tried both chassis with spare remote board and cable and exact same problem
I should say that I do not know if that spare chassis/remote board is 100% but strange to get the exact same problem if it isn't the tube itself.
I have another Sanwa monitor in my NUC cab so going to try these chassis on that tube to know for certain if it is the tube itself.
SO... if it is the tube, which I suspect it is. What is the solution? Is it a case for rejuvenation? Or is there a fix to be made to the guns?
Does anyone near London/South East do rejuvenation and how temporary a solution is it?
7,361CR
from what I understand ( which is not a lot ;) ).
carbon emissions can build up
Amd a fragment can fall off and create a bridge between guns.
The rejuvenator can burn the carbon away eradicating the short.
Your short could be between the other 2 colors reducing their intensity.
But I’m just thinking of different possible causes.
I have a tube with same issue and I have tried to look inside the kneck to see if I could see any sign of a short
