Ali express Jamma/jvs de10 Nano
2,209CR
Have you tried the jamma/vga dips when getting video via the Jamma connector to see if that makes a difference as it may be a toggle that switches between the voltage levels for arcade monitor vs TV (Something like 3volt vs 1volt). There also appear to be RGB adjustment pots on the board next to the jamma edge.
For the sound you may need to change the output to i2s, depending what the card is configured with, standard Analogue I/O I think uses i2s for audio.
2,209CR
When you say you tired to toggle SW3 on the DE10, do you mean from the bank of 4 large switches? According to the documentation you only want that one turning on if you are using a Digital I/O so you can use a second SDRAM module, which you dont want as the Jamma board is connected to the GPIO that would be used for the second SDRAM module.
https://mister-devel.github.io/MkDo...ect-dip-switch-configuration-on-the-de10-nano
7,368CR
I have sussed out getting the jamma edge to display rgbs video ( it’s a bit dull don’t know why or if I can get it better with diffrent config)
You mention i2 I don’t know what that is
And I have been reading the optical out is through the headphones Jack ?
Any idea on how optical out works ?
I would be happy with just that on board phono jacks working ..
I need to find the correct .ini file I think?
To turn the de-10 from digital sound out to analogue sound out .
As the Controll app only has options for hdmi sound as I currently have it configured
2,209CR
SW0 turned on enables Analog Audio output, The optical Out works via the 3.5mm headphone jack but you will need an SPDIF adapter to convert to phono
I would say you need analog audio output enabled to get audio from the Jamma Edge and/or phono output on the jamma addon.
BuildSW3SW2SW1SW0
IO Analog / IO Analog Pro (SPDIF) / MiSTercade V2 (DAC Module)OFFOFFOFFOFF
IO Analog Pro (Analog Audio) / MiSTercade V1.XOFFOFFOFFON
IO Digital / IO Direct / MiSTercade V2 (Direct Video)ONOFFOFFOFF
Take from here https://misteraddons.com/pages/guid...45liAomc_r9uTWOnjiaXwNBvc_q15s3sTWV2wsI-Tnh5G
2,209CR
i2s is the serial interface on the I/O board that gives analog audio output.
Optical out is via the 3.5mm Jack, you need an optical/spdif adapter to connect to it to get phono output via a 3.5mm optical cable.
See previous reply about turning on SW0 for analog audio.
7,368CR
BuildSW3SW2SW1SW0
Top…. Yeh will try
BuildSW3SW2SW1SW0
will give that a whirl ..
🤪 I did flip it but thinking it was for analogue vid
7,368CR
Did you get the analogue Audio working on this via the Jamma Edge or Phono connectors in the end?
I will try tonight bud 👍
Blew up my
Antoni jamma to mister that evening
Whilst 1 was going to try that.. so it has kinda slowed me down. ..
12v Down the 5v rails kinda thing that happens when you are wiring up a jamma test bench at 1 in the morning after getting the rest of the family to sleep !👍🥴.
But yeh pretty sure switch 0 toggled up is the the answer ..
Hopefully I can get into it later after work
7,368CR
🥴. Excuse me for being a total tool bag! My sw10 dips - First thing you are supposed to do. Naturally
I haven’t configured these - so I am assuming it is related to these not being configured .. my
Correct dips
🥴. Will try to get analogue sound again tomorow
7,368CR
All them Tiny dips were correct .
Still no sound ..
Ali express card working fine picture wise .. still working on sound ..
7,368CR
First real play test awsome ::
Just dodonpachi won’t screen flip & service menu don’t let
Me flip it either .. so flipped the monitor instead most of all the other games allowed screen flipIMG_8552.jpeg
7,368CR
Just can’t believe the quality …
Donky kong - i have never actually
Played the pcb so yeh ! Wow
I’m a very happy mister gamer right now 🤣🤣m🥳
Already thinking about what my second built will be …
Console cores /dos hooked up with a pvm & m32 pi & multi snacks I think
pooman2084
Be Attitude For Gains!
25 (100%)
1,873CR
Yeh I know .. but for some reason in button config it dose t have test sw?
I need test switch to save and exi game service menu?
There is a an option in the core menu to toggle the service switch. I’ve done it in all the Cave games.
You don’t define it, you just toggle it on, do your settings, and toggle it off.
