Problem Toei cm-r20 Green issue?
Ronnie Dent
1,163CR
Been getting this monitor cleaned up and ready to go back in the cab, I was getting a lovely white raster on first test but it soon turned into a green ever narrowing strip. I removed chassis cleaned and re capped it, all were replaced apart from the large smoothing cap and 2 of the four np caps as I only had two! Anyway I was greeted with a silent startup and a nearly full screen green raster, none of the r g or b pots change anything? I’m reading a b+ of 106v at the white ceramic resistor left side, is that too low? Hoping this is an easy fix? This is on the bench with no input and screen volts increased to see image.
Pic is before re capping
Thanks Ronnie
7,351CR
Maybe red and blue are not putting out ?
Cold solder under side of the colour circuits.
Or caps / resistors / transistors in the blue or red colour circuit.
7,351CR
Also check solder on kneck card res and blue input connector,
If not been used for a long period though ,
If you haven’t used it in a while
It worked then didnt …
Seems something was ready to quit.
7,351CR
You could pull a transistor from
Red or blue and test if it has gone short ?
Maybe be poss to test for short in the colour transistors in circuit but I’m not sure about that .. check schimatic of that transistor.
May be poss to read the emitter volts on the transistor /mossfet green , when chasiss is running ?
Then compare that to red and blue transistor / mossfet emitter when running .
If differing value then something wrong in the red / blue circuit ?
Big cement colour resistors on kneck card are usual suspects too! Normally visual sign of over usage on them.
Ronnie Dent
1,163CR
Cheers I don’t think there are any components on the neck card
There are some tracks on the component side and 4 of them were corroded under caps caused by the glue not cap leak on cleaning them up all 4 were open so had to bridge those
Never seen this one running, as said on first power up had a nice white raster and after a few mins I heard a high pitched tone and the screen had narrowed and gone green.
The manual is very good for someone who understands the all the steps etc but it’s mostly lost on me!
Cheers Ronnie
Ronnie Dent
1,163CR
So did some voltage checks on the r g and b I’m seeing 106v on them all inc the tabs of the transistors and on the neck card for each colour hope it’s not a crt issue
bernoli21
15CR
Sounds like you're on the right track with the recap, but that green raster and unresponsive RGB pots could point to a few things. B+ at 106V does seem a bit low-might be worth checking what the spec is for that chassis (some expect 120V).
gunblade
22 (100%)
8,845CR
looks like 200v vid b+ missing or issue on cut off circuits, if you had one gun short it will still be green so its not tube
those chassis are dogs, they suffer from corrosion from cap leakage and the tracks on the pcb are exposed so its likely one of more have been rotted away
Ronnie Dent
1,163CR
Ok thanks Grant, I did find 4 rotted tracks under 2 caps, they had not leaked it was the glue that rotted them, they were repaired during the re cap, I will have another look, I did remove the heatsink beside the lopt to get at the caps better and check any traces under glue so confident that area is good.
Thanks Ronnie
