Been getting this monitor cleaned up and ready to go back in the cab, I was getting a lovely white raster on first test but it soon turned into a green ever narrowing strip. I removed chassis cleaned and re capped it, all were replaced apart from the large smoothing cap and 2 of the four np caps as I only had two! Anyway I was greeted with a silent startup and a nearly full screen green raster, none of the r g or b pots change anything? I’m reading a b+ of 106v at the white ceramic resistor left side, is that too low? Hoping this is an easy fix? This is on the bench with no input and screen volts increased to see image.
Pic is before re capping
Thanks Ronnie
Thanks Ronnie
