In my 4 slot it was very randomly losing ALL sound, when switching game - this was only fixed by a hard reset.
I now think this is specifically triggered when switching to a pretty new AliX boot (Money Puzzle exchanger).
So I went through the morning (using only genuine carts) and systematically running one cart only in slot 1 alone then repeated for 2-3-4 in turn each for 30 mins then 2 slots occupied, then 3 and finally all 4 with genuine carts. The 5v was increasingly a little low each time so I upped it to show a true 5v with all four running.
Throughout all this testing everything was perfect so I thought I was sorted but later running with two genuine and two boots it again lost all sound when switching (to MPE).
So back to just running that in slot 1 alone - tried wiggling, then slight pressure on chips - all good throughout, no sound loss.
Currently repeating for slot 2.
Any ideas/help welcome.
FWIW - after a heck of a lot of 'discussion' GPT (sorry!) 'told' me:
- If sound drops system-wide, this strongly indicates:
- A failing Z80
- A bad or cracked 74-series logic IC in the audio bus
- A failing YM2610 or its DAC
- A failing NVC RAM used for sound
- Cold solder joints that break when warm
- our original random sound failures were almost certainly due to 5 V rail sagging below ~4.95 V when a cart was inserted, or minor contact resistance in slots or connectors.
- By slightly raising 5 V, the problem disappeared, and now all four slots are stable under load.
