Spoof red gun
7,319CR
I’m hoping it’s cold solder
But it normally is ok in morning when cold ..
But now it’s Stayimg
blue ..
I’m lookomg for cold solder when I’m he on kneck card ..
Then resistor on red circuit
And cold solder on red circuit anywhere ..
But just thought I would go to rule out worst case scinario first .
1,612CR
Quickest way to check tube gun is swap the red signal in wires red with green or red with blue
If you get red grass on a footy game or red sky on a Wonderboy or similar? Then the red gun is probably ok and the fault is more likely to be a transistor or associated red circuit component on the neck card as suggested by qjuk above ….
Also just check the pins at signal in connector are securely soldered .
7,319CR
Thanks,
Signal in wires?
I’m using vga.
RGB wires are solderd onto neck card ..
Só I desolder red
Desolder green ,
Then swap green signal to
red input ? And I should say get green blood ?
My red gun is good ?
7,319CR
Ugly blob of solder is
Grey wire coming from underside of flyback
Looks like G2 ..
Is this ok ? Something they did in factory to help ?
Or needs attention ..
Change resistor ?
7,319CR
Touched up them rings ..
It’s ok now ..
But I have got some other issues ..
I get like some issues when to much white on screen …
It jumps between a yellowy white and white ..
And I get some black lines from left to right in random places normally only for 5 min warming up then maybe once or twice now and then ..
