Solved Atari power supply help
Body pop
24 (100%)
1,032CR
I checked at the power supply (big connector plug unplugged )
I never actually checked with that plugged In as couldn’t get multimeter in there
So I would need to follow those points you showed me to somewhere I can get the multimeter on it then
38 (100%)
3,826CR
You can check at the power supply with the plug plugged in and power off to see if the resistance is very low, you will then know you have a short or not. You just don't know what's causing it this way but it's a start.
Body pop
24 (100%)
1,032CR
So checking at the power supply it’s showing 0 .
At the power supply with big plug plugged in
That’s in dc mode
On smart it shows this
Body pop
24 (100%)
1,032CR
Thanks 🙏
Below I took readings
First is with all connectors off pcbs
Machine turned off and big plug attached
next reading pic -with one (bottom)power connector removed from pcb
Last pic is reading with all connectors off pcbs
Is there any clues there ?
Body pop
24 (100%)
1,032CR
Has anyone any experience of running one of these on a switcher ?
4,764CR
The paperboy I had was fitted with Jamma PSU for 5v but I didn't wire it up, if I could get to my cabs I'd try and help as it's much easier with cab to look at what your doing but that's always my issue
Would have thought a few others here would know a fair bit on 720/Paperboy cabs to advise, not worked on them that much myself so far, mainly sorting PSU/Transformer for Toobin but not sure how that compares to these
Body pop
24 (100%)
1,032CR
Interesting ,as the bottom board in my cab is championship sprint
So I would imagine that would be the same
Would love to get this going again
Its giving nothin on screen at all now ,monitor comes on but its just blank basically
There’s also the 15 v situation,id need to find where it goes and check its getting that too
There’s always the mame option I suppose
Getting to the back of cabs is the enemy of having them
38 (100%)
3,826CR
You'd have to check to confirm before doing it but I think it's a case of cutting the ground and +5v wires I labelled (on the big plug) and connecting them to a switcher and leaving everything else as it is. I don't know what the +15v (AC?) is used for but if you leave everything else and it's working you wouldn't have to worry about it.
karlcdoe
875CR
Interesting, that looks *nothing* like the setup from my genuine Atari Ireland 720 degrees that came out of an arcade in Grat YArmouth in the mid 90's.
karlcdoe
875CR
The images posted above of the schematics appear unreadable on my pc however I made a very nasty test loom for Paperboy/720 from a scrap paperboy loom ages ago and most of it runs on +5v but you do need +15v to drive the video amp (I think) and/or hit the reset circuit over the head or you just get a black screen. I think it might also be used to tell the nvram to write the high score tabe before the 5v collapses on power down.
On the very faded masking tape wrapped around the loom it looks like the extra voltage needs to go to a pin on J15 on the cpu pcb and that looks to be a yellow/white wire one pin away from the edge on the end furthest from the 'key' pin and it is also conected to the power connector on the video pcb as shown in the pic above.
I suspect I might have got away with wiring it up to +12v on a switcher before I upgraded to a bench power suppply but time passes and recollection without revision has faded into that past :)
Obviously wiring +15v to any incorrect pins will result in terminal magic smoke escape so be very careful.
Body pop
24 (100%)
1,032CR
Great info today guys
Gives me some hope
Yeah those schematics are unreadable ,I didn’t even realise I’d posted them as I was the middle of writing a post
Worked out well though as some good advice here
The terminal magic smoke worries me
I’ll most likely try finding that 15 v and making sure its there
Then doing what ace says and putting the 5 v and grounds on a switcher
Can I safely use a separate mains plug for it for now ?
I think I came across a few of your posts in another thread while searching karlcdoe
Have you still got the 720
4,764CR
Champ Sprint is same boards but they used newer power supply stuff than the Paperboy cabs, question is was 720 same as Paperboy or Champ Sprint, that I can't remember, all require same voltages though
Body pop
24 (100%)
1,032CR
Before I do anything
1 and 4 are the 5v looks like there’s another red wire beside number 4 in 5 .could it also be 5 v
The grounds are 13 and 15 is 14 with the brown and black wire included in the grounds ?
Better being safe than sorry
4,764CR
Paperboy cab with Jamma PSU for 5v
See at the back of the switcher there is another psu where brown and red cables cut and wired to switcher instead
not sure whats going on with the AR2 is it? bottom of rear door, connector blocks joining wires
Without looking at manual I don't know how much that original PSU did, was it just 5V?
4,764CR
Toobin is much smaller board with the integrated audio rom board and amp but had the PSU missing (Arcade Warehouse job) I made one from 2 transformers and a Switcher, similar to original as in Champ Sprint, I know that needed something around +15v 0 -15v with centre tap so I got that +12 0 -12v one for that part, switcher used for most as they had them anyway which got the machine up and running though I have got original now that can go in it at some point
