Superstation One
18 (100%)
1,528CR
Also use various BT controllers, 8bitdo, Nintendo Switch online controllers. PS5 and Xbox series, all work fine and don't need to be re-connected each time. Are you using the built-in BT on the SS1? Or your own USB dongle? Not all of them are 100% compatible with the Linux os on MiSTer
tried a plethora of devices, i own nearly all of the 8bitdo range, they all connect fine, but then dont when the system is reset
its an absolute PITA because it means i have a USB keyboard close by when i turn the thing on
i've had this problem since day one with both the MiSTer and now SS1, it removes it before i re-adds it every single time
cools
I joined ages ago honest
18 (95%)
733CR
What mode have you had them set to? I can't be sure but I swear I had problems like this when I was using one of Switch/Dinput/Xinput with 8bitdo stuff and MiSTer
FrancoB
991CR
Do you know what wave you are in? You should be able to check your order if you log in. I'm in wave 4 and had shipping notification for the SuperStation and SuperDock on Friday.
Well, the tracking number didn't work at any point but it turned up out of the blue today.
Time to rock out with my dock out......
