Vectrex with problem need advice
vsl
67CR
Hello,
I bought a Vectrex with a stated problem: a white dot and no sound. When it arrived, I replaced the 2764 EPROM, the two 2114 RAMs, and the 6522 PIA.
The sound came back, and the white dot is no longer just a fixed dot, which is visible in the video.
But I got to this point and I can't find the culprit, please help and advise.
Thanks !
6,002CR
Do you have a scope? Hook it up to the XY output from the logic board. This will tell you if the issue is on the logic board or the deflection board.
6,002CR
Use two probes and put the scope in XY mode. Digital scopes aren't very good at displaying vectors, but you should be able to see a rough version of the game playing. Do you have a test cart or a flash cart you can put the test cart ROM on? It will help to see if vectors are being output correctly from the logic board.
  • Like
Reactions: vsl
vsl
67CR
Guys, thanks for the idea! This is my first real experience with a vector system, so I honestly didn’t know about using the oscilloscope in XY mode for this kind of diagnosis. 🙂
That’s actually a brilliant trick — basically turning the scope into a second vector display and comparing what the logic board is generating with what the Vectrex CRT is showing.
I’m learning a lot from this repair already. The machine started as a silent white dot, and now we have sound and actual vector movement, so at least the patient is definitely alive. 😄
Thanks again for pointing me in the right direction — the hunt continues! 🔧
1,868CR
Classic CRT oscilloscopes are best for this kind of things. On most of them, one can use the Z input on the back too.
  • Like
Reactions: vsl
vsl
67CR
Hi everyone!
Despite trying everything I could think of, I'm still having problems with my Vectrex. At this point, I honestly don't know where else to look or what else to try to get the console working. I'm really eager to finally play it, so I'd be very grateful for any advice you can offer.
Since this is a US console originally designed for 120V, I've replaced the original transformer with a toroidal transformer with a 230V input and a 2 × 9V AC output. Both 9V outputs are stable.
I've also replaced the following: 4066, 4052, MC1408, LF347, LF353, ROM, 2 × 2114 RAM chips, 6522, and LM379.
I'm uploading a short video showing how it currently behaves.
vsl
67CR
I inspected them, wiggled them, resoldered them, and wiggled them again. They aren't causing the problem. When I touch their solder joints underneath the board, the picture distorts in all sorts of directions, but the lines that should be dots remain lines.
vsl
67CR
I've removed the logic board and I'm starting to check every trace for continuity. I suspect there's a broken connection somewhere.
6,002CR
Integrator caps might need replacing.
Please say if you have tried adjusting the integrator pots, or not. Last time of asking!
  • Like
Reactions: vsl
vsl
67CR
Yes, I’ve tried adjusting both integrator pots (R333 and R335), as well as the size controls, but the problem remains. The frames are still badly curved, the text is distorted, and individual dots appear as short lines. The LF347 has already been replaced too.
Thanks for the suggestion about the integrator capacitors — I’ll check C312 and C313 next.
vsl
67CR
Thank you big10p and Georgian2 !!!
Your help has been amazing and really helped me pinpoint the problem. There are still some imperfections in the picture that I need to work on. I may ask for your advice again if I can’t manage to fix them.Тhis is my first experience working with a vector display system, and I’m finding it very interesting! :)
