Atari Breakout
forcefulfil
EDOT King
1,657CR
grobda said:
nice work :)
I wouldn't recap the monitor as the picture looks fine.
until the old fekers pop!
caps dont like to be left for years they dry up,i think a few £ saves all the hassle they cause
but what do i know
andrew96
Unfixable? What's that word mean?
899CR
Back then capacitors were so much better, they will most likely never go! It was only later on when the electrolyte formula was stolen and passed on did the problems of bad caps start to happen as the formula was wrong, important ingredients were missing, so the caps worked but several years later that's when the problems showed up!
Back in the 1980's I don't think i ever changed a cap unless it was on some HT line of 450v or so, It was always something else capacitors going was not heard of really.
grobda
1,061CR
forcefulfil said:
grobda said:
nice work :)
but what do i know
only hassle i've had from caps is ones that have had physical damage;
partly pulled off then pushed back on again
punctured by stacking pcbs
broken legs
dry joints
IMO electrically they're sturdier than their reputation might suggest.
jus my 2penneth
Morty
68CR
Mesmeric_G said:
I have found that a "filler primer", works really well on pitted surfaces left by corrosion. It is a really thick primer that you spray on, and then wet 'n' dry right back until all you can see is the primer filling the pitted bits.
yeah its great stuff but no use here i'm afraid
this control panel should be bare aluminium so i need to remove the corrosion then reinstate the brushed look. i looked how to do that but the corrosion is ultra
toughttough
