Chunksin Images Download Links
RygarR
410CR
sicoe said:
Good Morning All
Im looking at giving the GroovyMame image a go and i have a Lenovo M90  3244 PC 3.2GHZ With 8gb Ram but it only has onboard VGA, I want to try this in a Sega Astro City will the onboard graphics be ok or should i purchase a PCI/E Graphics card and if so maybe a HD 7450?
Thanks Simon
Hi there. I think it depends on the onboard GPU. One of my MAME PCs has an AMD chipset with integrated GPU - it's an AMD A8 7600 - and that works fine with Groovymame / 15 KHz.
chunksin
21 (100%)
733CR
Yep, as Rygar says if you have an Intel CPU and only on board graphics it won't work, you need a compatible ATI/AMD chipset for the low resolutions. Drop me a message if you get stuck or have any questions
sicoe
16CR
Thank you All
This is what i have
https://www.cnet.com/products/lenovo-thinkcentre-m90-3244-core-i3-530-2-93-ghz-monitor-none-series/
Will it take an external graphics card
Thanks Simon
Vamino
Insert coin(s)
2,690CR
I've been messing with the Groovymame build using a HD7450 and it's pretty easy to set up!
I had a few issues using a HD3450 getting the custom resolutions to work.
One thing I'd like to sort out though, I want to set this up for a friend who'll be using a TV. His 4-5 year old son will be playing on it unsupervised so it need it to be plug and play with no screen adjustment reqd etc.
What resolution should I choose so all the games fit on the screen?
Also, when I tested vertical games they seemed to be running in interlaced mode?
Does anyone have any hints and tips for setting Groovymame up for use on a TV?
Cheers.
Retrojedi74
86CR
Hi all, I’m using a pi2jamma and I wanted to see if anyone has any pics of the pi2jamma thingy image if possible. Would anyone on here have any to share? Cheers
Venom
796CR
Hi I see in the thread there is quite a lot of discussion about gfx cards and the document reccomends
Radeon HD7450 1GB PCI-E x16 Low Profile Graphics Card
These are about £20.
I plan to also run some emulators on the pc like a dreamcast emulator. Is there any advantage or recommendation on spending £30/40 on a card or no real benefit. Just wondered what a next recommendation up would be, or if that would just be a waste of money ! I think they do hd7540 low profile in 2gb's as well . As a lot of people in thread seem to have low profile setups thought would ask here.
Venom
796CR
The 7450 does DX11. 2gb I think is a min so one I can see new so I guess more current is the gt 730
Just unclear if that will be a major benefit over the 7450 , for emulation mame,, dc ps2 , wii etc
https://www.ebuyer.com/736224-asus-nvidia-gt-730-2gb-low-profile-graphics-card-gt730-sl-2gd5-brk?_sgm_campaign=scn_8714e1eb7e000&_sgm_source=736224&_sgm_action=click
Will have a look on google.
trev1976
170CR
I use a HD7570
https://www.ebay.co.uk/itm/0KFWWP-AMD-Radeon-HD-7570-1-GB-GDDR5-DVI-Display-Video-Card-Low-profile-/184914341060?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=710-127635-2958-0
8,243CR
trev1976 said:
I use a HD7570
is this what you use for demul?
if so how does it handle ?
i’m looking
to add demul to groovymame
8,243CR
Is there a default usb drive letter ?
For scrapping / searching usb for roms ?
I’m trying to add roms to the macrium groovy image .
Instant sheller etc..
Will this stop usb drives being recognised ?
As I exit attract mode search for usb pen drive in my computer and it’s not listed ?
Is this my pc up the spout?
trev1976
170CR
Hi
I built a PC with this image a while ago and it's still fine but I was thinking can I upgrade my motherboard and CPU in future without much hassle ? I'm currently on a Q9550 4GB Ram and eventually would like to upgrade to I7 3770 8GB Ram as I run other Emulators on it and it just can't quite handle Dreamcast / Atomiswave
chunksin
21 (100%)
733CR
You might be OK, I can't remember if Windows 7 does a license rearm on new hardware detection, if it asks for a key let me know and I can provide you with one
justserii
0CR
Another quick question: I am having some trouble with the pi2jamma thingy and a 2 player blast city layout. I have it all hooked up properly and it is working with both a Naomi 2 and PinHP, but for some reason the Pi2Jamma Thingy image wont detect the second player. None of the buttons work, but Up and Right on the joystick swap between Tate/Yoko. I searched the config files, and searched the settings while it was running and couldnt find anything.
Does anyone know how to set up 2 player with it?
