GroovyMAME / Groovy Arcade Help!
pooman2084
Be Attitude For Gains!
25 (100%)
1,873CR
Hey folks.
I have a couple of 2human MAME setups from around 2014 (details lost in the J+ debacle).
I had one for vert games and one for horizontal. The vert one was a bit more powerful to run Cave shooters etc.
They were in storage for a few years but I had both working last week in my JAMMA cab. The cmos batteries had gone so I needed to redo the settings to get it to boot from USB.
My vert game started to lose settings, for example my additional key mappings disappeared, then I lost my game lists, now I can’t seem to save lists or key bindings between boots.
I thought I’d have a look at the USB drive in my PC but apparently it can’t read Linux drives. I’m left with a setup that can’t retain lists and boots to a blank Groovy Arcade options screen.
Is there a simple way to ‘reset’ the install back to defaults or do I have to reinstall? Should I update anyway given they are a few years old now?
I purposely got these PCs so I didn’t have to worry about faffing around with MAME as my tendency is to go deep or obsessive about electronics. I wanted to avoid spending more time tinkering than playing and was comforted by 2huwman setting it all up to boot quickly at 15hz and lag free.
Any help to get me up and running again without having to learn a new operating system would be very much appreciated!
7,361CR
yeh these older ones are prone to this.. i have had it
bloody annoying.
like if you set up a pc with groovymame and used it it would keep conflicting with the keyboard.. and normally it’s the letter I if you can get another modern jpac i wouldn’t be surprised if your fine..
i had an older ps2 jpac go on me last week the sync no longer works i don’t know why either, but they may me repairable ?
Venom
727CR
I have a 2human pc set up as horizontal. Even when I managed to read the USB on windows you dont see the individual files, you see the linux type stuff.
If you want to send me your USB happy to plug it into my cabinet and see if I experience the same. ?
May as well wipe one issue out.
I have mine set to LCD though as 15k screen went bang.
Venom
727CR
Do you still need any help as I have access to the filesystem now if you need anything.
I have just bought a 9020 to replace the groovymame pc but can grab what you want of it, as wil take me a while to do a new build !!
