Hantarex MTC 9110 instant glare
gunblade
22 (100%)
8,760CR
check things like marquee light, power supply voltages, maybe a few caps on chassis ( 22uf 250v ones in particular and anything in the 200v video b+), try different game board to prove no issue on signal
gunblade
22 (100%)
8,760CR
you disconnect the tube, you need to read your voltages etc, check your video ground continuity
does every pot work on the chassis including the sub brightness pot?
myazgan
5CR
yes all pots are working.
check your video ground continuity :
video gnd 14.pin in jamma harness is idle, can it be related to this. Or is it another issue you mentioned?
myazgan2022-05-17 12:29:59
