hantarex polo/2 -28 help
Scoobyatgb
10CR
Here is a picture of the pcb board the game that is in the cab is golden tee 98
If the picture does not show here is the link
https://ibb.co/eJFGCwScoobyatgb2017-12-11 20:39:37
M K L
1,099CR
That's a Polo/2 15khz only. As you can see in this chart the b+ for 25"/28" is 140V if the tube is Videocolor and 145V if the tube is Philips:
If you measure 174V and can't lower it to 140/145V with the b+ adj trimmer there is a fault in the PSU.
gunblade
22 (100%)
8,890CR
the same issue can happen when there is a fault on the horizontal output circuit or bad flyback, unless you have a bad solder joint I seriously doubt this is going to be an easy fix
also unless you have experience with monitor chassis you should not be messing around with this, purely from a safety point of view- in theory you could kill yourself
scares the sh*t out of me when people with no electronics experience mess around with stuff that has hv and seriously nasty dc voltages
why don't you send it to someone that can repair it, there are a few people that do this- myself for one and tb2000(tony) also
