Help with 486
7,265CR
Typo on line 2 in config.sys:
DEVICE=C:\SB16\DRV\\CTSB16.SYS /UNIT=0/BLASTER=A:220 I:5 D:1 H:3
Should be:
DEVICE=C:\SB16\DRV\CTSB16.SYS /UNIT=0/BLASTER=A:220 I:5 D:1 H:3
I can't remember if it all has to be on one line or if it is allowed to be on multiple lines.
Thanx. You are correct this continuation of a line was causing an error.
I have corrected and tried a few config changes mainly just altering the sb set up
A:220 I:5 d:1 H:1 p330 T6
But no joy yet !
Including this video of my post script .
Hopefully this can help
I still cannot seem to get to a diagnose utility ..
Sb16 legacy dos set up help , no sound
7,265CR
Thanks, I recall mixerset.
Will check tomorow.
I also looked at bare irQ ( minimum irQ’s needed enabled as I don’t have cd rom drive
I don’t have mouse ..
I know sb is irQ 5
And my bios currently has irq5
Plus 10,11,12,15 as well as 2and 9 enabled .. ( can’t need all them!)
I hope I’m juat having a irQ clash
I don’t recall my bios irQ before I plugged my
Keyboard into the second ps/2 port. And this is my issue ..
Here is my irQ settings
When Hexen helped me hé used a diffrent irQ to the recommended .
it’s A220 I:5 H:3 p330 T2
Will confirm this tomo as I have backed up image .
I’m just thinking that me plugging the keyboard into a diffrent ps/2 port has auto changed the IrQ’s ? And I need to reset them to how they were?
Also I think I need to disable parallel ports completely .
Will have ago tomo at this.
7,265CR
What I have done is used macrium to create a backup of the ide drive that was with the 486 when I received it.
Then I have restored that to a ssd .. No probs until recently when I swapped keyboard cable ps/2 around into the second avalible ps/2 socket.
I have just taken original ide and
Plugged it up and all is ok sound is back .. or never left this drive anyways ..
30 January 2026
Now I will take another copy of this drive and try that on the ssd .
And then up date how that goes
But look like when I changed keyboard socket its changed
Stuff in a config file ?
One strange thing is my 486 thinks it’s Christmas all the time now ?
Snowing on my arcadeos front end .. 😅 I can live with that.
mlynn
121CR
That's good news! Is there an SSD drive with an IDE interface?
A friend of mine had a PATA laptop and managed to get an SSD for that but the performance was very choppy. Not consistent read speeds.
7,265CR
Yeh I’m using ide to Sata
Works fine for what I’m using it for only like £5
Another change that occurred to my set up was . My coin mech / credit .. no longer worked ?
But all other controls did …
And when I went into in game tab menu to set it, It didnt allow me to. It just went to - None - As if my credit coin mech micro switch was now mimicking Keyboard stroke esc!
Só in a nutshell
Swapped keyboard cable around to second ps2 socket.
Results.
No sound
486 is stuck on Christmas Day
Says merry Christmas in post script as well 😁.
And has messed with keystroke set up on my ipac.
Could all these things be in one
Mame.cfg ?
Maybe a mame default.cfg?
Anyways
I have formatted and restored the ssd going to try this morning, hopefully …
All this because I was tired and plugged ps2 in wrong socket ! 😆
7,265CR
All good !😁
31 January 2026
Breathing better now …
Back to normal
Now going to right everything down on papper and keep it inside the cab.
It’s still Christmas though só I’m thinking bios battery has died maybe ? Check this next
