MCR Interconnects
4,048CR
[ukvac] MCR Interconnects
I know these can be bought from Bob Roberts. SCSI 1 cables that i
beleive you just let the 25th pin hang off the edge.
But does anyone have access to the kit to make these up? I could use
about 40 of them i think. I'd need to count them up but it wouldn't
surprise me if it was roughly that kind of amount!
http://www.homearcade.org/BBBB/mcr.html
Ta,
Martin.
david_orton_2000
Green Mario
341CR
[ukvac] Re: MCR Interconnects
Martin,
I just use a vice to squash the IDC connectors on.
There is a tool of course, however it's only worth it
if you need it all the time.
Could buy a reel of IDC cable to seeing as you need loads?
Aircon=False; Fans=True
Cheers,
4,048CR
Re: [ukvac] Re: MCR Interconnects
Good point!
Since i found the connector info for that post i'll see if i can grab
some connectors and cables next time i order...
Ta,
Martin.
G
Guests
Guest
Yes... Much the same here.... Use a vice or a tool that goes in a
vice. The propper IDC tooling is expensive. I have a roll of 50
way cable kicking about somewhere.
Cheers, Colin
G
Guests
Guest
Personally, What I would do is to buy a pre built scsi cable, with as
many connectors on it as cheaply as possible....
Go for something like the 8 way one.
http://www.homestead.co.uk/productcategorydetail.aspx?categoryid=51199
Each conector is spaced 6 inches apart..... Now all you have to do is
crimp some extra connectors onto the cable to give you the desired 4
inches or whatever then trim the cables.
The beauty is that having half the cable crimped up already reduces the
screw up margin by 50% :)
Also why not go the full hog and fit 50way sockets to the boards (with
the extra row of pins and the end pins timmed back ?
Cheers, Col
4,048CR
WOW! These things ain't cheap are they??
:eek:)
I started off thinking those 8 way ones were quite a lot at £10 each.
£18 each by the time you've added the 8 extra connectors needed to get
the interconnects down to within the spec (assuming 3" would be long
enough, but i think that's much longer than the original ones). That
would give you 8 interconnects. So, two lots of those would do you 3x
MCR boardsets for £36.Mmm. That's doable when you break it down like
that. £12 a boardset.
You price up the cable (£25.45 per 30m roll) + the connectors at £0.99
each (and that's the >25 rate) and all of a sudden you can see why
they're so much!
So, to do a single MCR boardset from scratch (5 ribbon connectors)
you'd be looking at £10 in connectors + the cable if you made it up
yourself. Theres probably really not much in it between making it from
scratch and butchering a pre made one.
Then again. Looking, CPC have the above 8 way cables for a fiver +
VAT. That's quite a difference. Will have to do some better maths this
evening when i'm not meant to be working.
Maybe put out some requests for quotes like Bob Roberts originally did.
Martin.
4,048CR
Okay, let's stick me neck out and ask who'd be interested in a set IF
i sorted this out (big IF).
Set of 5 x interconnects suitable for use on MCR boardsets.
Email me off-list on martin <AT> guddler.co.uk with the number of
set's you would be interested in.
Nothing set in stone, just so that if i find someone that can make
them up reasonably rather than do it myself, i know what quantity to
ask for.
Martin.
> :eek:)
> they're so much!
> Martin.
pobtastic
476CR
RE: [ukvac] Re: MCR Interconnects
I'll have a set - you never know when having a good set will come in handy.
They are the major cause of headache usually for faulty boards, so having a
known good (new) set is a good start at determining what the fault is!
Pobster
d-type
172CR
You might want to try Connexions Ltd., a company who specialise in cables.
http://www.cxcxcx.com
Several years ago, I used to use them for customised cables for control and monitoring projects I used to run.
For example, they used to do soldered 25-way D-connectors to your spec. for a few quid, in low quntities.
They might be competetive.
For the IDC connectors, I had a tool which cost an arm and a leg, but on site, doing them in a vice never gave any problems.
D-Type
On Mon Jun 20 13:46 , Guddler <guddler@gmail.com> sent:
>Email me off-list on martin guddler.co.uk with the number of
>ask for.
>Martin.
>> :eek:)
>> they're so much!
>> Martin.
4,048CR
Cheers Phil,
I knew you knew of a company, but i'd forgotten who it was.
I will indeed try them. If i can get someone else to do them at a
reasonable cost then all well and good.
Martin.
PS: The proper IDC crimp tool is only £7 odd +VAT in CPCs catalogue,
but i have a vice (no comments please) so guess i could save that £7
anyway.
> D-Type
4,048CR
Hmm, okay, well full marks for speed of response, but "Nil Points" for
customer service.
Quote:
WE ONLY DO AS 60CM LONG
NAS
And that was IT!!
No, "Hello, thank you for your enquiry" or anything like that, and
yes, it was all caps.
If i weren't to assume better then i'd think that was a five year old replying.
Any other suggestions?
Martin.
> D-Type
