Hi guys,
Hope you can help me out?
Basically I got this Electrcoin midi from the barn raid and when I fired it up the monitor was dead. No neck glow at all
First thing I checked was the fuses at F1 and F2 and they are ok
Second thing I checked was the power on the 4 pin connector going into the monitor.
One side read 250v AC, the other side reads 157v AC
I probably didn't need to do this but I also changed the flyback on the chassis
However I am still in the same scenario
Today I thought I would check the B+. Now I've read various methods of doing this so hopefully I've done it right?
1) I connected the red probe to SP3 connection at the chassis and the black probe to the metal chassis. Got a read of 187.3v DC
2) I connected the red probe to SP4 connection at the chassis and the black probe to the metal chassis and got a reading of 29v DC
As a secondary check I put the red probe in the middle holes of the connector on the chassis end into which the scan coils are plugged into, which gave me a reading of 26.3v DC
So from what I've read the low B+ means this can be 3 things:
1) The cap at C34
2) The regulator circuit main power transistor
3) Resistor R110
If it's none of these three then possibly BU508 Transistor
Also I've looked at Randy Fromms flowchart but it doesn't really help me when SP4 is too low and SP3 is too high
I'm not a monitor expert so any help would be appreciated
Purity2014-01-11 15:46:28
1) The cap at C34
3) Resistor R110
