Just use some low melt solder and iron works fine, or low melt and hot air as uses a lot less heat
Never done it that way before. I usually drag solder, then check with a microscope. As for removal, I’ll shield surrounding components with capson tape and baking paper as to not short anything.Just use some low melt solder and iron works fine, or low melt and hot air as uses a lot less heat![]()
I also normally just drag solder and lift with Tweezers unless it's an ASIC then I paste a heatsink on top, low melt and hot airNever done it that way before. I usually drag solder, then check with a microscope. As for removal, I’ll shield surrounding components with capson tape and baking paper as to not short anything.
Looks like they're about £4 each, so say £5 each flashed + postage.Yes please. How much would you want each?
I’ll take 3 please. Dm me your paypal and i’ll sort it later. Thanks!Looks like they're about £4 each, so say £5 each flashed + postage.
