No flippers :-(
bbz149
26 (100%)
1,608CR
Ben yYou sure the othe half is not sabotaging your machines
ben76
Hunts Spies
1,136CR
pooman2084 said:
Did you get this sorted?
Nope not yet.....
To update.....
I ordered a replacement fliptronic but they were out of stock. Then got an update from Luke saying he is still trying with my pcb. So far my faulty fliptronic has blown part of Luke's Indy pin when he tested it in it. Had every chip replaced, had burnt track damage fixed, been plugged into his scope. I said shall we give up and his reply was "I'm not letting a stupid flipper pcb get the better of me" He also said some clever tech stuff that means nothing to me
I'm currently contemplating finding another fliptronic and selling it if my ever lives again.
I'm sort of in limbo atm with it
also got severe pin withdrawals
- Ben
pooman2084
Be Attitude For Gains!
25 (100%)
1,872CR
Get over to the UK Yahoo lists, or get Andy Netherwood from Pinball Mania on the case.
There is NOTHING that man can't fix. There is a reason why he is called THE LEGEND.
I hate admitting defeat on a repair, but we need you back flipping ASAP!
ben76
Hunts Spies
1,136CR
I'm happy with Luke looking at it
tbh everyday I'm getting closer to buying one of those Rotten Dog (I think they're called) ones.
Also my games room is a sh*t tip atm so the pin is doubling up as a table
- Ben
ben76
Hunts Spies
1,136CR
Ok so after so long not being able to play on my pin..... Today a
fliptronics pcb arrived from PinLED. I've put it in and still no
flippers
any ideas where to try next?
Also it now spits out 2 balls instead of 1 (still does this without the fliptronic connected)
Its made me a sad panda
- Ben
ben76
Hunts Spies
1,136CR
The fliptronic was confirmed as fecked. So needed replacing anyway. Luke still hasn't sussed the original one. It looks like its taken something else with it when it went as it did when Luke plugged my old one into his Indy table. Just need to find where to go next. As much as I want to play it, I'm really interested in fault finding and fixing it
- Ben
ben76
Hunts Spies
1,136CR
Stop Press......
We now have flippers
Now to do this I disconnected the wires and put them back on again....
It still gives out 2 balls instead of 1. I did a bit of (play) testing (
had to be done!) and it seems to know there's 2 balls in play and sort of works ok when you lock one of them as you carry on with the other 1. However it will end the game if you loose 1 of the balls on ball 3.
So... I did a factory reset to see if that helped and its now in German and still giving 2 balls
- Ben
ben76
Hunts Spies
1,136CR
not sure...
I've done a bit more (play) testing and it seems to be sendign the 2nd ball in automatically. The ramp microswitch works fine as with no game running if you press it the plunger fires. If you lock 1 (or 2) ball(s) for multiball and you're on your last ball it knows where you're up to and plays fine.... unless you lock the last ball, start the multiball then loose 2 of the 3 as it then goes to game over... If that makes sense?
- Ben
lowlevel
69CR
Check your trough switches in switch test. These are physical switches
Getaway has 3 balls in the trough.
Your symptons mean you have bad (stuck) trough no 3 switch (counting from the right)
When one ball is put in the shooterlane, due to your bad no 3 switch, it still believes it has 3 balls in the trough, so it spits out another ball.
5,461CR
^^ What he said, test them in test mode!!!
pooman2084
25 (100%)
1,872CR
Go to test levels - it will cycle through the active ones telling you what they are. If you're missing the 3rd ball, check wiring and the physical button.
Cheek plug - I still have a Getaway manual for sale if you need diagrams etc.
