Phils Arcade Thread - Workshop build
Phils Arcade
1,391CR
Well, as is tradition, when the nights come early and the frost likes to bite your toes, it's time to do a bit more on the workshop.
With the concrete base down over the summer the rest of the framing and roof structure needs to be added. Due to the span of nearly 9 metres we need 2 metal beams to be installed. Got a structural engineer, who literally lives round the corner, to visit the site and work out the beam sizes needed to support the roof. These were bigger than I had initially thought, but best to trust in the experts. Although I also asked ChatGPT for its recommendation and it suggested the same, so no issues there. These were ordered and delivered to the house. Now how does one shift 2, 9 metre chunks of metal weighting nearly 300kgs each.
We managed to use a plank to shift the beams onto some round wooden posts and start rolling these like in the Middle Ages. This worked out well, until we hit the hill section and the beam just wanted to roll back down again. Bring in the wench, sorry I mean winch. This was bolted to the concrete floor and the other end attached to the beam. We could use the plank to shift the beam up the hill and have the winch to take up the slack preventing the beam from rolling back.
This technique worked really well, and we managed to get both beams shifted up onto the concrete floor in short order.
Next issue was how to get the beams lifted up to their mounting places on the wall and timber supports. The timber supports has a 10mm metal plate added to help spread the weight of the beam on the wood. I had looked up our local hire shops for some inspiration, and found beam lifters. One was all that was needed. Hire out for the weekend and the jobs done, right.
NOPE!
The lifters were all out on hire and wouldn't be back until January at the earliest. I was hoping to get the beams up so I could get the roof rafters installed. So how to get these heavy lumps of steel lifted 3 and 4 metres into the air. Think, there must be another way.
Getting the shopping from Tescos and packing the car, I just happen to notice the scissor jack for lifting the car when changing the wheel. Hmmm, would this be able to lift the beam. Short story, even shorter, yes.
Working on one side I'd lift the beam up, slot a concrete block into place and lower the beam back done onto the block, then do the same on the other end, and back again, each time lifting the beam 6 inches at a time.
The whole process was slow, but managed to get the job done. Then came the moment of truth, was it level. As you can see, if it was any more right, it'd be wrong. One down, one to go. Dismantle the blocks and start over again, only this time it's a whole metre higher. There wasn't enough blocks now, so ended up building a platform that allowed the beam to sit on it and freed up the blocks under it. Again using the car jack, one side at a time.
Now both beams are bolted into place, it's time to get the first set of 20 rafters up. These all need cut in to fit around the back wall and beams. Job for the weekend I think, weather forecast, snow :)
Max...
337CR
Reminds me of one of my first jobs - working as a roofer's mate - first day, flat roof - two stories up - me (young innocent idiot) standing by the towering ladder and looking at the great big gas cylinders next to the flat bed truck: "Cor - how do you get those up there then? Reply: "ON YER BACK SON!!" :LOL:
Phils Arcade
1,391CR
Okay, just a quick update. As was forecast, the weather was indeed snow, looked like a wonderful winter wonderland.
Even so, managed to sneak in a wee bit of work on getting the wood bolted to the top of the steel beams to enable the rafters to be screwed into place. The first set of rafters was added, around 20 needing shaped, and screwed in. Have got the majority of the side framing now done, and about to start the front wall. I've allowed a large entrance to enable a Luton style van to reverse in to ease offloading cabs and materials.
Even with the cold, I'm amazed at natured surviving.
Hoping to get the front wall finished this weekend and the final set of upper rafters, depending on weather of course.
Once complete then it'll be time to get the whole place boarded out and wrapped. Getting more excited now it's starting to take shape.
Phils Arcade
1,391CR
So, with the first house renovation now out of the way, it was time to get back to the workshop build.
Took delivery of a bail of 18mm hardwood Plywood sheets for the roof and boarding out the walls. That's 50 8x4 boards, all needing shifted from the front to the back of the house. Times like these you wish you have a forklift truck, lol.
These all need to be painted. I'm using a wax based external paint to help protect them while they are installed. This task fell to the wife and Rogan, although the supervisor selected the right paint to use. This will eventually get covered with building wrap same as the first half of the build.
Have managed to board out the back wall and started on the lower side section.
Next up was getting the front wall framing started. I've left a nice large door to allow a Luton style van to back into the workshop to on/offload equipment and materials, though there's a massive mound of dirt out front that will need moved first.
This leaves the last of the roof section to get done. As these are all the same, it's best to make a template to help speed up production of each of the rafters. Makes such a difference to the accuracy as well.
Just another 18 more to go.
This leaves getting the cross member for the loading door area and the space above it to be framed out, allowing the front and rest of the side to be boarded out. Hopefully it'll remain dry this weekend again and we just might, get onto boarding out the roof.
7,326CR
looking good phil . 👍.
Good size ..
Have you thought about rubber on the roof?
One piece rubber ..
3 people ..
Nail gun.. ply and rubber in a day
A friend told me recently that a firm hé worked on had a rsj and roof actually totally collaps. Taking out a side wall with it. I just had some pig of a steel .. we all had to take turns with a sledge to smack it in to position I think it took 300+ swings easy ..
it moved Less than .1mm with every swing it was so tight
Phils Arcade
1,391CR
What a great size and good progress! Do you have quite a large garden? Any issues with planning? I'm hoping to do something similar in the future.
I've about 3/4 an acre of land around the house and a few sheds, though I somehow manage to keep filling them up and needing something larger, lol.
Planning wasn't any problem. A set of scaled drawings, Geo maps, and a few visits with a promise, that once built I'm not turning it into a bar.
