Close up of the sticker on the side. I'm going to try and remove it. Now I look at it in detail it's obvious to see it's been fitted quickly as the ends aren't trimmed properly and there's a random bit stuck on lower down the cab.
Complete loom is out. I've noticed with this cab there's a specific way it comes apart. You can't remove the loom without taking out the coin box container as it's screwed in behind it, then that won't come out unless you undo the coin door. So I'll have to remember that when I put it back together.
What was left in the bottom of the cab.
Oh look it's the missing connector from the opto board!
Time for the Henry-Sheen double team. Jeez that actually rhymes...looks like that's a new phrase then
Inside fully cleaned and polished. Came up nicely.
Before
After
Before
After
