Pole Position II restoration
2,259CR
Had a chance to do some more to this at last at the weekend.
Cleaned and recapped both AR2's.
Monitor is back having been repaired by tb2000, thanks mate. Turns out it had pretty much everything wrong with it, lopt, hot, caps, transistors and other stuff - not an easy repair!
The good thing is after it was cleaned up it's actually got only a tiny bit of 'game over' burn which is really unusual for this game and a good result. I can only guess it's been broken a long, long time.
Bezel fitted.
Brick cleaned up.
Loom has been cleaned so starting to rebuild the cab a bit now.
Mr20to5
1,366CR
Terrific progress Olly. Really impressive differences between the before and after pics. Just been going through a few of yours and others resto threads. They are also great reference tools as I plod on through my Zacc.
Neil
smarty
Ready Player One
1,302CR
Its cleaning up nicely isn't it.
I would recommend you replace the 2N3055 transistors on the ARII's if you haven't done so already, I had one fail and it put 7Vdc all over my PP board, now that made me feel
I replaced them but ended up with running in a switcher for the 5V supply.
2,259CR
I'll gladly take that advice! I've got some coming today so I'll replace them before I do the first power on test.
2,259CR
Voltages all looked good initially, but when I hooked up the pcb first time I got absolutely nothing.
Metered and was getting 0.8v max so clearly not going to boot the pcb on that!
Took the AR2's back out, replaced the 2N3055 transistors (as I should have done before) and also did the sense mod on both. Replaced them today, checked voltages again and have perfect 5 & 12v lines.
Hooked up the pcb again....
[tube]sC67GAoDdGQ[/tube]
Not getting any sound at all, no hum or anything so need to look at that next.
muddymusic2015-06-02 15:19:00
smarty
Ready Player One
1,302CR
Nice seeing a PP come to life with real hardware.
Also check fuse F3 on the powerbrick, that can be changed to a 25A (Was in an Atari bulletin) if it isn't already, some peeps also recommend soldering the wires for this fuse instead of using the crimp connectors, I did it at F3 as my fuse holder had been well an truly burnt away...
2,259CR
Rebuilt a decent shifter from the 2 broken ones I got with the cab
Stripped and painted metal parts, cp requires more work as the old adhesive is being a pain to remove.
Marquee light required a new tube and starter, luckily had both in my spares. Cleaned up and fitted to the cab.
Coin door and service panel back together.
Pedal back on the cab. Just the control panel and wheel to sort now.
2,259CR
Fixed the sound. Appears that although the 2 AR2 boards look the same they aren't and need to be a certain way around. Really pleased to have it running 100% now.
[tube]qfqkHQdh1Wo[/tube]
Mr20to5
1,366CR
Great to finally hear this working as well as just seeing it.
Good job to get it this far.
Nearly finished. I played this a lot at my last visit to Arcade Club and rekindled some fond memories.
Neil.
2,259CR
Time to get this finished. The CP was proving to be a total pain in the
ass. The overlay came off fine but left behind pretty much all the
adhesive which refused to come off in the conventional ways.
In the end I left it out in the sun for a week to dry it out, hoping that might make it possible to remove.
Got myself a new scraper and pack of stanley blades and set to it. After much scraping and moaning it was clean at last.
Gave it a light sanding, and got 3 coats of spray paint on it. I've started using Black Cobra paint, it's a bit more even and easier to work with than the plasticote stuff I usually use, and gives a pleasant textured finish.
Once dried it was finally time to get the new CPO fitted. Put a lot of work in to this one, and it was worth it as it looks bloody lovely.
Trimmed
Once that had adhered nicely I could finally fit the wheel and shifter.
2,259CR
This is one of the more difficult restos I've done. Needing work on the cabinet, the loom, the pcb's, the ar2's, the brick, the lighting, the monitor and the artwork. Apart from that it was peachy
A few pics of how it was when I got it.
And how it looks now.
