Programming Tesla MH74S287 ?.
cliff_poole
1,069CR
I bought some of these PROMs from ebay some time back and have only just had a need for one.
From new, they read as all zeros, when I'd normally expect to see FFs. Looking at a recent ebay description, a seller says that their un-programmed state is probably opposite to a 82S129.
Both my Data I/O 29b and Chiplab refuse to program them as National 74S287.
Does anyone have any ideas of how I could get around this ?.
Mitchell Gant
884CR
I'd be interested to know if these PROMs are truly compatible to 82S129 's too.
From the 82S129 datasheet http://pdf1.alldatasheet.com/datasheet-pdf/view/91518/PHILIPS/82S129.html
It says 'Unprogrammed states are low level' so I'd expect a new blank device to read all 0's. So your Tesla chips DO match an 82S129. They're not EPROM technology remember, which do generally read as all 1's (0xFF)
If a 29b can't burn one then I don't hold much hope for other programmers. I've got a Dataman 48UXP that will do some PROMs but certainly not all of them. I got sent some Harris PROMs instead of 82S129s I wanted (long story, seller sent me non -blank ones at first). They DID correctly read as all 1's when blank but sadly my Dataman could not program them.
Macro
1,982CR
Mine only lists National as well (Xeltec ones)
from a quick search, Elnec programmers list them in case any one has one of those!
cliff_poole
1,069CR
Thanks, a blank check on the Chiplab confirms that they are blank so that is probably right.
I found a datasheet for the Tesla, but gave up trying to read it.
My attempts at programming as the following have failed,
Signetics 82S129
AMD 27S21
National 74S287
TI 24S10
Harris 7611
Fujitsu 7114
The most promising of those was the Fujitsu 7114/L, as it was the only selection that passes the blank check on the 29b.
I also managed to mess up one chip, it changed one bit (incorrectly), when attempting to program as an AMD.
cliff_poole
1,069CR
Just out of interest, what do you think "Verify at address 0", would mean while programming ?. The device remains blank and un-touched. Is it saying that it can't drive the address or data lines ?.
Macro
1,982CR
a lot of programmers verify as they go along, so they write a nibble / word (depends on the chip) and then read it back to see that it took, so it could just be saying I tried to write the first chunk (address 0) and read it back, and it was wrong
as you say the document is not easy reading, it could be that they need a different programming voltage or different timing to enable you to program them - on one programmer I have (if I still have it!) there was the option to change the timing of the write pulses, but on the one I use the most it is all preset for each maker / chip
Equites
Chief Sheesher®
35 (100%)
3,306CR
Sheesh, the 29b is the king of PROM programmers. If that can't do it I don't know what can.
Also try;
[font="Courier New, Courier, mono"] 93427, 93467 Fairchild
MB7052, 7114 Fujitsu
3621 Intel
IM5623A, IM5623CPE Intersil
6301-1, 63S141J, 5201?, 6201? MMI
24S10, 34S10,SN54/74S287 TI
29661 Raytheon
DM7574/8574, DM7597/8597 National
[/font]
Equites2014-03-03 01:10:37
death69inc
3CR
Wish I would have seen this post before I paid for tesla chips lol
seemed to do same thing even tried the AMD and overvoltaged one chip lol
Only programmer i have found that has them listed in device list so far is
In US - bk 866b and 867b but at $1k to $1.2 k yeah i think ill take the hit for a few hundred proms
in UK - Elnec beeprog2 same as above just different company name.
But they do have one hell of a device list going for it lol 93454 device supported
But out of my price range. Looking for an older solution without doing the home made bit by bit programming.
Love my 29b and my emp20... but with prices of proms to me going crazy I need to find a way to program the cheaper solutions. cant afford to spend $30 $40 on a 3 proms for a $150 $200 Arcade PCB.
Was hoping maybe someone has come up with a solution????
Equites
Chief Sheesher®
35 (100%)
3,306CR
death69inc said:
Wish I would have seen this post before I paid for tesla chips lol?
seemed to do same thing even tried the AMD and overvoltaged one chip lol?
Only programmer i have found that has them listed in device list so far is?
In US -  bk 866b and 867b but at $1k to $1.2 k yeah i think ill take the hit for a few hundred proms ?
But they do have one hell of a device list going for it lol <b ="error" style="font-family: Arial, Helvetica, sans-serif; line-height: normal;">93454 device supported[/b]
<h1 style="margin-top: 5px; margin-right: 0px; margin-left: 0px; padding: 0px 0px 10px; font-family: Verdana, Geneva, Arial, Helvetica, sans-serif; font-size: 18px; color: rgb85, 116, 157; line-height: normal;"><span style="color: rgb0, 0, 0; font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 12px; font-weight: normal; line-height: 16.8px;">But out of my price range.   </span><span style="color: rgb0, 0, 0; font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 12px; font-weight: normal; line-height: 16.8px;">Looking for an older solution without doing the home made bit by bit programming. </span></h1>
There is a solution, substitute an EPROM for the PROM.
Ace`
PlanB contributor #1
35 (100%)
3,719CR
My new (old) Stag System 3000 lists these as supported, I can try it if you want to post me a blank chip.
Edit: Nevermind I just noticed this is an old thread, my offer still stands though.
Ace`2016-01-16 13:55:00
