Have to check that amp and see what connections you needThanks for the reply
I used this
Hacked the aux connector
Looks like I’ve messed ut up quite badly
I had read
Connect pins 2 and 4 the grounds to the ground of the spliced wire
Then connect the other two
Left and right to left and right of this spliced wire
Then connected speakers from the cab and 12v
great stuff . many thanks for thisView attachment 66758
Pins 2 and 4 from board will go to the combined Jack plug Ground then Pin3 (P105) to where the tip connects to on the audio female jack connector on the audio board then 6 (P105) to where the Right Audio (middle section) of the jack connects to on the audio board. If you can find the pinout of a female PCB mounted jack connector then you will know where to connect on the amp board with the female jack connector removed.
No problem, let us know how you get on wiring the audio up and if you get soundgreat stuff . many thanks for this
