This rarely happens to me....
kingtreelo
18 (100%)
1,540CR
Them contacts look
long shot but them contacts do look dark/tarnished .
Try a little clean up
on them ..
de oxidisation…
You got -5v on your cab ?
Just incase sound is ok and game is running .
Them contacts look
on them ..
de oxidisation…
ill have a look at v, do different PCBs need a different voltage setting?
bear in mind this PCB came out of my non working cab, i put in my working cab and got nothing, i cleaned it up already, nothing form it at all, no sound, picture..nothing
7,361CR
I always try a few cabs now as it’s common to get diffrent results due to diffrent connectivity ..
Ideally this wouldn’t be the case …. But as you have stated already slightly diffrent voltage .. can change result also the condition of your jamma harness and pins / psu ..
Worth comparing your psu voltage output with a multi meter .. aim for 5v maybe try 5.1 v
-5 required for sound on this one do you have it ?
This board can play blind.
the psu is dead in this cab
With this game then maybe over volts from a failing psu culprit .
kingtreelo
18 (100%)
1,540CR
yeah, i suspect the latter, if the psu went pop it may have fried the board, my other PCBs work fine in the same cab, ill see if i can get the power issue sorted in the no worker first i think, i wasnt really planning on keeping the PCBs, it just would have been nice to have 3 workers
