Twin Sega Mame Driving Cab Upgrades, LCDs, I/O FFB, Wiring....
4,766CR
Needed some new wiring for mains side after removing transformers with new connection for LCD with Kettle Lead, then adding in 24V PSU for Forcefeedback to Immersion board, as I had wired in before also with monitor not powering up till PC powered up I also added in the FFB PSU and mains power to the Subwoofer for audio so if machine plugged into mains only PC Power is in standby
I've taken a few old Microwaves apart and something else and the 12v 16amp relays are great for it, cut out that part of the circuit board and add pc ide power connector or fdd to switch everything on with 12v
Same wiring done for both machines so inter changeable between them
