Twin Sega Mame Driving Cab Upgrades, LCDs, I/O FFB, Wiring....
5,272CR
Blimey over a year ago I was doing this. been quite busy working on them again as years ago I bought some of the later Immersion FFB I/O boards from member here or may have been J+ and it was about time I got to work on them and get them fitted
I originally used Act Labs wheels stripped down for wheel/Pedal setup and was going down amplifier for voltage to power these motors but the all in one Immersion is perfect setup when I have the matching wheel mechs, another reason for those was I was thinking I could also Run a Dreamcast in the cab to play the driving games on that but with emulators and pc's good enough now we can play them all
As I'd fitted everything to the back of the dash and now really needed to fit the new board in machine base so time remove all from dash and start again and do everything twice as it's twin cab as other half loves driving games also, new wiring as it wasn't best job before, bits of wires joined everywhere, this time using more Amp Connectors and sega wiring with matching colour all way through, can use pin from connector to remove the pins/plugs from them and solder wires to them so look neat, got a box of sega wiring so nothing to buy apart from one 4 pin connector used on the shifters which i'd only got one, wasn't joking I'm reusing all the cable ties also as no need to waste anything
Speaker system has 5.1 sound so I added centre speakers where the older cabs had dash tweeters, not sure if games are really going to use them but kept them and wired back up
5,272CR
I’m not familiar with this type
Of set up ..
Looks interesting
.. will this add ffb to the
Dreamcast racers emulated on a pc then?
same as the Sega Rally 3 i'm working on
Dreamcast games only had Rumble Pack, not sure if anything added in emulators to enable that through the wheel, be good if they had though
5,272CR
Original PC setup was a Gigabyte board with AMD 64 Athlon II X2 270 3.4ghz, when i came to switch left cab on they wouldn't boot and shut down again, turns out the plastic tag the heaksink clip goes on snapped off, the other cab was okay last year but when i came to swap over the pc in that one its done the same, anyway they were getting outed for the new Ryzen ones
to fit PC's in I used some old case plates, ones that were removable from main case, this one was a pain as bottom at back extends lower than the rest so I needed to raise it up, some plastic trim off cuts from secondary glazing done job nicely, cut the extra off the top rear and reduced the length of the metal base
The other one I'd fitted in before the new wood to test games running
5,272CR
One seat had what I assume was original wiring the other nothing as cab only had front speakers from new, so i've copied the wiring from other to make this one better, added the correct 2 pin connectors as i had some spare for gullbox speakers, before they were both a bodge with joined together wiring and you had to unplug all the cables from Subwoofer in base if you removed the seat and stripping that down was a pain so I've done it in stages now with 6 pin amp connector (seat sub and gullbox speakers) then to an 8 pin amp connector to add in the Handbrake cable which then sticks out enough to connect under the seat hinged plate
Mess before with it all joined and any old wires used
can unplug each stage of seat strip down now and extra cable between for seat adjustment forward/back
5,272CR
Much neater now and can unplug seat to remove it with one connector
Made new loom for subwoofer in base to seat speakers and subwoofer and sufwooer to front of cab base to front speakers copying other cab
5,272CR
Nice progress mate. :)
I've been battling with the software side of things and thanks to some help I'm getting near the finish line.
Cheers man
It's taking a bit of work, it would be much quicker if I had 100 rolls of different coloured cables, new connectors and crimps but then that all costs money so it's keep going through boxes of old cables, sorting out colours and if I have enough of it, removing pins from old connectors and soldering wire to it, it's long process :LOL:
Software time is nearly upon me, 3 cabs to sort it on, 2 exactly same so I can ghost it to another drive hopefully
Might need tips from you on it :LOL:
5,272CR
Volume control wiring re done from Dell (Samsung I think) Subwoofer system, it had a plastic front on it originally but i removed that, the Sub vol control was on that front panel so I've replaced connector to AMP and redone matching colours from that to front of cab base to go to Coin Tower, again it was a bodge of wires and joins before
Had loads of Red, Yellow, Purple, White in various AWG so used thinner inside cab and gonna use thicker for link cables to coin tower
Red for Main Volume and Purple Sub to differentiate between them
Vamino
Insert coin(s)
2,667CR
Cheers man
Happy to help if I can.
If it wasn't for a certain forum member I would have chucked it all in the bin, I kept encountering weird issue after weird issue, pure torture.
I had to go with W10 in the finish, I had issues with my Low Profile MSI R5570 MD1G when trying to use Chunksins embedded W7 image and with bog standard W7 Pro. I just couldn't get Launchbox and CRT Emudriver working for love nor money, crashing video driver when installing CRT ED and also issues when trying to install Launchbox, I had missing/malformed certificate nonsense with that. Luckily the monitor is 31khz, so using W10 I ended up forcing windows into 480p mode with VMmaker/Arcade_OSD.
I also had an annoying issue where the A-PAC acted like a digital input device with pots attached, no idea what that was all about. That drove me nuts for a while, made no sense why it was doing that.
Some of the best advice I got was to configure Launchbox/Bigbox to run from USB, get it all configured and dump it on a USB stick plugged into the PC. Can transfer the whole lot over easily then.
I literally have to force myself to spend time finishing it now, it put up such a fight that it sucked all the enjoyment out of the build. I've been a bit busy with work and other stuff I've not a had the chance to finish it off, but it's closer to completion now. And if I was to do it all again, it wouldn't take long at all.
Things are always easy when you know how. lol
5,272CR
The whole A-Pac saga has messed up me plans now, the damn Clutch is the issue with board not setup to support it even though hardware present, looks like i'm gonna have to use 3 USB device now with I-Pac for stuff also or it's add extra buttons to enter and exit games etc
5,272CR
Got the Bass Shakers a few weeks back so got cracking taking seats apart again to remove the Sub Woofers and see what these are like, so thought i'd just cut flat plate to fix them on and fix to seat similar to Subs, metal for first cut out from an old door on machine that needed replacing, the metal the gas strut fixes too and only has one, for the sake of a bit of weld to the side frame they get bent and then whole top lid replaced and more stuff thrown away.
2nd one from awful old speaker stands, i'd already cut part out of other else they'd be matching lol
Added same connector to cable as the original subs so i can swap back if I wanted
So after the seats all back together and fitted, the verdict. I can now turn up the main sub in the base without the seat subwoofer just making a racket
you don't get as much from it as I thought you might but I suppose it depends on the frequency allowed through it, but when you do get some low bass like end of intro on Grid it shakes the seat just nice and outrun 2 when you pass the trucks/coaches you know about it :LOL: so it's good addition when you have a sub already on the small cab speakers teamed up with this adds a bit more though to get more from them being able to adjust frequency it works at would probably help
5,272CR
Next thing that needed sorting are PC Power Button and Volume Controls as it was a quick job with bits i had lying around before so I thought I'd do a proper Service Panel, these were bolted to each side as it was for each cab
From what I can work out the service panel must have fixed into the clip part at the top on the angled top inside and you have 2 screw holes to fix from underneath and it sits behind the left box the cables go through up to panel but i'd like if further forward so volumes easier to reach when you have many different games to select from so done my own idea, so back in the metal fabrication department
5,272CR
Quite pleased with how this has turned out, redone all the wiring after going through all I have, I needed same colours from door and panel through the coin tower, connecting cables from tower to machine base and through base to the I/O boards other side which is much better than the mess before
Wasn't sure if needed but thought I'd add them anyway so like sega cab it has Test, Service and instead of Degauss I've used Red only for PC power switch
Sanwa Buttons and Vol Knobs from PiHut site which are very reasonably priced and postage only £3.50 for next day and they did.
Black vol Main Speakers, Red for Subwoofer
in Initial D 4 it has Test and Service buttons so I configured for these and you can press both as screen says when its on card cleaning screen at game start up and it works :)
Got 5 and 12v from PC power supply going to tower just incase but just using 12v currently, I added 6 pin amp connector so coin door can be removed easy, then splits in to 6 and 10 pin for coin mechs, service buttons and going to serparate connector for each machine with another connector for vol control/pc power button machine end i can fit all in one 18 pin amp which base panel already cut out for
What a game it was getting wires through the plastic which was on some Sega cables but makes them look much neater at back of machines when all connected too tower
Vamino
Insert coin(s)
2,667CR
Any reason why you are using a clutch mate?
Always impressed with your fabrication skills. :)
On my old IDv2 cab I had a transducer on the back of the seat and kept the sub under the seat, that gave the best of both worlds and everyone that played it felt like it added something to the game.
5,272CR
Yeah I wanna be able to play everything and Hard/Race Drivin has clutch for manual gears and Ridge Racer which is a switch but far as I know you need to use it on manual gears, people have got F355 running with full manual now. also be nice playing PC stuff like Richard Burns Rally as I have handbrake also :)
5,272CR
I had 3 of these PSU's from some sky or freeview boxes probably, 1 pin short but only need out of the 9 for the Immersion button matrix
Requires diodes for upto 16 inputs for being POV so I thought best idea is them on veroboard reusing the ones on the back of dash before with new terminals on
because of how these are wired it needs separate ground to each button, its a bit confusing but layed out with 16 connections for buttons 12 without POV you have to group 4 switches together or less so like the 4 View colour ones are grouped, the Credit, Start, and paddle shift are another 4 and then up/down shifter, handbrake but if I end up using I pac that will all change again as some of those like view buttons and 1 and 2 player start would need to go on I-Pac
So I used those pre done conenctors with solder tab connection other end to link together, nothing wasted here or new required then 2nd done pretty much same
