What are you measuring relative to?
I think measuring for 11VAC and 18VAC between the 3 lines shown is the most useful thing.
Yes, from those videos it seems it doesn’t take much time at all from the engaging of the motor test to seeing the car move left, it’s almost instant where as mine is trying, skips the left and heads right, stops at the limit switch, does not return to center and then game starts with it stuck on the right limit switch.
Ok, John, measurement off the brake light molex, between pins 3 & 4 I only get 11. 4 and then between pins 3 & 5 about 3.8. I’m not seeing any DC voltage between pin 7&8, just AC.
@Mykill2.0 can you please check your brake light molex with a meter and see if it's the same or is it higher?
I also tested the transformer points, game is 120v being US, 60hz, verified. All of the voltages there seem to be correct? so wondering if it something, even 1 is not carrying through properly to it's destination?
Just let me know if you need me to check anything.
Brake light?
Transformer:
Main: 120v / 60hz
