Solved Atari power supply help
Body pop
24 (100%)
1,030CR
Hi guys
Would anyone be able to rebuild this power supply or any recommendations on anyone that could please
I took it out and cleaned it .after game stopped working
Changed the 5v fuse which came apart in my hands .cleaned around the fuse holder which was black
and it worked for a few seconds
It’s out of my 720 euro cab
Thanks in advance
Body pop
24 (100%)
1,030CR
So I’ve taken this out again and gave it a better clean
It has blown 5v fuse
Is there any way of cleaning that fuse holder for the 5v
I’ve noticed this crud on this part shown ,is that glue from factory just
Or could that possibly be my problem with 5v blowing ?
Or is the /could the fuse holder be the problem ?
Body pop
24 (100%)
1,030CR
I’m going to have to change this fuse holder for sure
Soldering onto a board .oh no
Is there a way maybe I could use a switcher for the 5v just ?
38 (100%)
3,810CR
You could use a swticher for +5v and use the PSU for the two AC outputs (if those still work) would require some hackery though. Shame it didn't use the same setup as the US version as it looks like that uses a standard switcher and a transformer for the rest. You do like the oddball stuff though. ;)
Do schematics even exist for that power supply? I cannot see a model number or any markings.
Body pop
24 (100%)
1,030CR
The boardset is Atari ,
you know me to well with this oddball stuff 😂
The only good thing yo my advantage though ,maybe is ..
The pcbs are Atari,so maybe that makes things better for schematics
It was all working and playing
There was a small smell of burning when it turned itself off
I’ve almost convinced myself it was the dust on the power supply burning .no smoke
It also made a sound of the coin counter clocking up
The 5 v fuse holder is broken for sure
My belief is that everything else is working
Though what could have caused the 5v fuse to blow .maybe years of use and it was maybe slightly burnt up ?
Maybe it’s the only problem
38 (100%)
3,810CR
It looks like there was poor contact on the fuse which caused high resistance that then creates heat, then that creates more resistance and so on until eventually it just burns / blows the fuse. Same thing often happens in pinball machines.
I could recap it and replace the fuse holders for you but the issue comes with testing it, I don't have a load tester or the pinouts for it.
Any idea what that is between the power supply and transformer that looks like some sort of bomb? If it's a filter cap for the +5v that could have shorted.
4,697CR
I'd say same with fuse holder poor causing it to heat up, get that replaced and probably be fine
Pole Position 2 I had was dead when bought it, funny how people always joke about sellers saying its probably just a fuse and all that was wrong with the cab was someone had fitted a Car Fuse holder instead of original, no surprise it was all melted and fuse blown as they are designed for 12v not 240v, replaced correctly and cab was up and running, okay it wasn't fully working as slight gfx issue but I only paid £10 so was happy with that lol
Body pop
24 (100%)
1,030CR
Thanks bods that’s the hope 🙏
I’ll have to practice soldering to a board first though
I’ve avoided it for years since my last effort
4,697CR
It's a lot easier than Welding :LOL: don't use cheap solder, heat the metal pin and pcb pad and solder will just flow round if it's all clean, I've got some cheap solder I got free but it's hard work with that rubbish, long as it's decent brand with flux cores you'll be fine.
To practice you could just practice tinning end of wire, if you can do that okay you'll be fine, watch some youtube vids first I'm assuming they'll be some, I do it for things I'm not good at, get some good tips too
Body pop
24 (100%)
1,030CR
I watched a video a couple of nights ago and he made it look very simple
Just have to watch one on how to remove the original part now 😀
Body pop
24 (100%)
1,030CR
@Ace` I managed to miss this post Not sure how and had a go at the soldering
If your still up for capping it that would be great
Or alternatively if you think it could be still problematic with the other monster thing that’s there
Would a switcher be the better option
Would I be using it for 5 v only ?
38 (100%)
3,810CR
I think it would be best to keep it original and hopefully just a new fuse / fuse holder and recap will be enough to bring it back to life. The large filter caps are probably fine but I'd replace the rest if you want me to do it lmk.
Body pop
24 (100%)
1,030CR
Hey Paul
That’s great if you can do that at some stage for me
Let me know when suits and I’ll send it over
Cheers again for the help
Glenn
Body pop
24 (100%)
1,030CR
Back to this again
Ace kindly put new fuse holders etc
On the power supply and the after service has been second to none as usual
My power supply was even held by Royal Mail for a couple of weeks as suspected it wasn’t allowed to fly 👀
So measuring the voltages at the two power connectors
I’m getting almost 7v with no load
This is being lost somewhere though as with just the top power connector off and testing it .its only showing 0.95 v dc on that connector
With it connected 0.85 at top board
Test point
What’s my best option from here ?
Another member also kindly supplied pics of inside their Atari 720 which has a switching power supply
Is this as simple (of course not simple lol ) as getting a 15 amp switcher and taking the red 5v and brown grounds,getting power to it and using the other big suspect device for the rest of it ?
4,697CR
img_6034-jpeg.58893
That the 5v to PCB then I assume, I would get another connector same so you could just unplug that one, connect up switcher and connect 5v with new cables to that if going that route
Aren't any of the 3 pots on the original psu to adjust voltage?
Body pop
24 (100%)
1,030CR
Thanks
It has a connector up there too
Which is 5v also and the one that appears to be causing it
The left hand pot I just tried again ,moved the voltage from 0.92 to 1.1
Is it advisable to move it anymore
Great idea about using smoother connector for the 5v if this doesn’t work out
There’s another separate fuse holder that appears to have 4 red wires going to it and checking with continuity they are linked to the 5v
Maybe I’m losing voltage there as it came of and I tried to solder the four wires to fuse holder again
Body pop
24 (100%)
1,030CR
Well I’ve changed that fuse holder on left of pic .The one with no fuse in it there
It’s four red wires soldered on one side and one on the other side
I’m now getting dim red lights on both game boards at times
Voltage is now up to 1.5v on top board which is double what it was
I’ve also disconnected the coin counter at is was clocking randomly
Surely it wouldn’t adjust from 1.5 to 5 v would it ?
