Solved (solved)Dig-Dug sound scratcy but not all of it.
1,785CR
Hello,
here i have this two board set that has an weird scratcy sound. Not all of it is like this. Any idea what could be?
Thanks a lot.
Start at around second 28:
1,785CR
It looks more like an inputs problem? The dig-dug does not stop and still moves slowly if no button is pressed. If buttons are pressed, it moves normal and the sound is ok. Weird.
4,224CR
Then maybe you have bad resistors that I assume are to hold the pins high?
Check the socket without the chip and see if the affected parts of the sockets are high. If not them maybe a resistor has failed.
