Dos mame , sound blaster issue
8,230CR
It was
C:\ “ edit “👍
I I owe you a beer at this point ,
are we getting somewhere ?
8,230CR
image.jpgI have managed to edit
The autoexec.bat Só as to
Remove the “REM”
And set rem to the bottom line with the irq10 ..
Now my games run but I don’t have sound .🧐
big10p
Coins detected in pocket!
6,050CR
So, you have Windows installed and not just MS-DOS, right? Have you edited MSDOS.SYS to boot straight to DOS? It's a hidden file in the root directory which you first need to make visible with the command
attrib -h -s -r MSDOS.SYS
then edit it and change
BootGUI=1
Logo=1
To:
BootGUI=0
Logo=0
See if that helps.
Hexen
489CR
BootGUI=1
Logo=1
To:
BootGUI=0
Logo=0
See if that helps.
And then reapply the hidden, system and read-only attributes.
8,230CR
BootGUI=1
Logo=1
To:
BootGUI=0
Logo=0
See if that helps.
Thanks this acer logo is doing my head in..
8,230CR
BootGUI=1
Logo=1
To:
BootGUI=0
Logo=0
See if that helps.
I actually don’t know if i have windows installed .
I can she’ll dos to a wind 98 command prompt screen
8,230CR
Ok só I updated SB drivers and then edited autoexec.bat.
In that order so will I require to update drivers again or can you edited the autoexec.bat without the need to update drivers ?
8,230CR
BootGUI=1
Logo=1
To:
BootGUI=0
Logo=0
See if that helps.
Any space’s ?
Is it case sensitive ?
