Mega Force PCB?
sukhbir
45 (100%)
1,606CR
What is the (wait ) signal doing on the the main z80cpu ? If it’s low the program will never run,I had this issue on my star force board set Where the watchdog was constantly barking.
sukhbir
45 (100%)
1,606CR
This repair was for a 3 board set starforce with an encrypted cpu .At location J5 (74ls02)the wait signal comes from pin 10 and this was low,pin 9 was floating.
Traced pin 9 to a 74ls74 at location L4 where pin 9 output was floating,replaced ls74 and game booted and program was running but with corrupted graphics which I’m still trying to fix.
pull the cpu out of its socket and bend the pin 24 upwards so it does not go back into socket and tie this to +5v using a 1k resistor and see if it boots.
big10p
Coins detected in pocket!
5,614CR
Thanks for the info. I'll give that a try. 👍
big10p
5,614CR
I've tried pulling the WAIT pin high, but no change. The RESET pin is still toggling. Should I try pulling RESET high as well, or is that a bad idea for some reason?
sukhbir
45 (100%)
1,606CR
oh dear bad luck,dont pull up the reset signal,this looks like it’s going to be a tough repair as there’s no schematics.
I would next try to locate the work rams and scope the outputs,check all pins .
big10p
5,614CR
Yes, I'm thinking more and more this board is a complete dud. I will probably end up replacing so much stuff, it'll be a Trigger's Broom by the time it's working. Lol
In anticipation of the work ram being duff (since all other SRAM was dead), I've bought some 6116 replacements. I guess these are the 2 on the left of the Z80 that I need to look at?
I guess with no working CPU it's going to be difficult to tell if they're faulty? I will probably pull them anyway and socket a couple of new 6116s.
big10p
5,614CR
Fujitsu alert-the LS02 above left of eprom 02 is a Fujitsu,try piggybacking it to see if it makes a difference.
I'll need to buy some. Think there's a few more Fujitsu ICs on this board. Should I replace all Fujitsu chips as a matter of course, or just certain types? I've heard they're prone to fail.
Lurch666
21 (100%)
4,171CR
They fail often but fortunately piggybacking can show improvement most of the time. Don't replace them unless you know they are bad. Just slice them if you are not sure.
favouredson
Super Star
1,253CR
People should stop obsessing about Fujitsu ICs.
Yes, they had a period where their ICs were frequently sub-standard, but not all Fujitsu ICs produced during this time were dodgy.
Focus on actually finding the real faulty IC(s) rather than automatically suspecting any and every Fujitsu IC on a PCB.
I have numerous PCBs with Fujitsu ICs and, shockingly, they still work 40+ years later.
Of all the ICs I have replaced over the years Fujitsu account for no more than 10% of the total.
Remember, these items were not designed to last for the length of time they have, so be thankful that they still work at all...
Lurch666
21 (100%)
4,171CR
I agree with that. It's not always fujitsu.
But I've fixed a few PCBs simply by piggybacking fujitsus because when they fail they fail open so a piggyback works.
It's not a technical method of diagnosing issues but I just want to get a board working so I always start with the simple things.
big10p
5,614CR
This is a learning exercise for me, so I'm trying to trace what's causing issues, rather than just guessing and replacing stuff. Difficult without a schematic, though.
big10p
5,614CR
Still working my way through this, tracing back to find why the watchdog counter isn't getting reset.
Having to trace back through a load of ICs has been tying my brain in knots, but I've found it stems from an ls139 (dual 2-to-4 line decoder/demux) that seems to be used for memory addressing.
A certain output on one decoder needs to get pulled low regularly, in order to reset the watchdog counter, but never does, because the enable pins (active low) for both decoders on the chip are being held high by the output of a couple of OR gates on a HC32. This causes all decoder outputs to be held high, despite activity on the input pins.
This HC32 and another one connected to it are both faulty, but looking at the way they connect to the ls139, I can't see how they can enable the decoders even when working. Anyway, I'll give my old brain a rest and replace them both, then continue the adventure...
