Mega Force PCB?
Lurch666
21 (100%)
4,265CR
Can't find a link at the moment.
It's a simple probe (I just use an old multi meter lead) that connected to the green input of my test monitor with a switch.
If the switch is one way the green video signal comes from the PCB under test but if the switch is the other way the green signal comes from the probe.
Touching data or address lines with the probe will show on the monitor as green if they are timed with the video signal thus possibly showing which parts of the circuit are related to video.
big10p
Coins detected in pocket!
5,678CR
I learn something new every day. 👍
big10p
5,678CR
I've managed to get spites displaying properly. Issue was basically a bad connection on the sprite RAM.
This board has water damage and corrosion all over the place, so this is a general problem. Pretty sure this is going to be the main issue with the background tiles, as pressing down on the board in the right place improves things.
Text layer looks good.
Fixing the earlier via continuity issue also brought sound back to life. Almost jumped out of my skin! Lol. Has issues like tunes are a bit off, and a couple of missing sound effects, but as stated earlier, sound is being left until last.
Georgian2
1,804CR
Nice progress.
Coroded sockets suck. If pressing on the board changes things, you either have bad sockets or bad solder joints. Like you said, most likely coroded sockets.
Great work!
big10p
5,678CR
Nice progress.
Great work!
It's a nightmare as trying to reflow joints, the solder just doesn't want to flow and stick. Fibreglass pen helps, but I don't really want to desolder, clean and reflow every joint on the board. Lol
big10p
5,678CR
Right, I think I've managed to fix all grahpics issues, but further play testing is needed. The tile issue was indeed just down to bad contacts. I had already replaced a few of the tile ROM sockets due to corrosion, but decided to replace all the remaining ones too, as they looked OK-ish, but not great. I managed to locate the main issue was with 3 particular ROMs, by proding around while the game was running. Turns out a previous trace repair I'd done when fitting a new socket had come adrift. I prefer to try and fix traces if possible, instead of simply fitting a trace wire. Another issue was with a particular ROM. I'd cleaned them all up as best I could, but a leg on one ROM was pitted, and on closer inspection, had a hairline crack right across it. I ended up pulling off the leg and soldering on a new one, as solder didn't want to stick to the old, pitted leg.
Next up is sound. I'm guessing the missing sounds will be down to a fault in one of the channels, but the Bomb Jack schems aren't going to be much use to me, as that game uses three 8910 sound generators, whereas Star Force just has Z80 based sound.
big10p
5,678CR
I'm amazed at how well you have done with this.
It's victories like this that keep you going at PCB repairs.
Thanks. I have spent a lot more time on this than experienced fixers like yourself would need. Trying to get my head around how everything works etc. Still plenty still left to learn. Almost gave up a couple of times, but it feels great to have got this far with it. 🙂
No way I'd have got this far without SLICE, btw. Being able to watch the functioning of ICs and working out if something looks off has been extremely useful.
big10p
5,678CR
Sound fixed. 🙂 With no schem to give me any clues about the sound circuit, I used my audio probe to find the sounds, starting at the opamps. Tricky, as the missing sounds (explosions, one of the tune channels etc) aren't always playing, so trying to probe and play the game at the same time. 🫠
Anyway, I discovered that this board uses three SN76489 sound generators, and one was outputting the missing sounds just fine. So, the signal must be going AWOL before reaching the amp. Turns out sounds are piped through three 4066 analogue switch ICs, and the one handling the missing sounds was ropey when probed. Replaced it and now all good.
I'm happily calling this board fixed and am very pleased. Thanks for all the help. 👍
sukhbir
46 (100%)
1,629CR
What a mega repair 😁,well done,great fix.
big10p
5,678CR
Nice work.
Now for the conversion...
I'm a bit confused about the Baluba ROMs. They're numbered 0 to 17 in MAME, not 1 to 18 like Star Force, and look like they're ordered differently?
Here's my top board (pre-fix photo):
And, this is a photo of Baluba from the net:
Where does ROM 0 even go?
