Like a range doublerNot sure about resistors, but the op amp is probably only necessary with the og monkey ball stick.
That stick has an over-sized restrictor disc, so the pots don't see the full range of motion as the default config.
Op-Amp gives greater sensitivity over a smaller range of movement.
It's to add more resistance to the pot. It's only needed if using an op amp for the, completionist. The original stick use 5k pots where as the Gundam one use 1k pots.
With the Gundam stick wire directly to to analog port you get pretty close reading to the original MB. If you use the Gundam stick without the resistor and an opamp the game is unplayable as its way to sensitive. You have to do the mod to the pot or change the value on the opamp
@Retroman839 do you know what sort of pots you have in that Sega stick?Option 1:
Get close to original sensitive. Wire directly to stick. Will need 6 wire, if you only have 4 you will need to piggyback the power and ground.
Option 2:
If you want close to original sensitive, don't want to modify your harness and want to use the amp. Ad a 2k resistor to pin 1 and 3 of the pot.
Option 3:
If you want to use your amp and want a little more sensitivity add 1.6k resistor instead of the 2k. 1.6k is about as low I would go. On one of my stick on one of the axis I max out . The other 5 pots are around F5
Option 4:
If you want more sensitivity but don't want to add resistor to the harness. You need to make some changes to the op amp. If you don't want to desolder the old resistor you can add a 50ohm resistor (I only have 52.3ohm on hand) in parallel to R11/12 and a 2k resistor (I only have 1k on hand so you will see 2) in parallel to R2 and R9.
Have you tried wiring things directly and seeing what happens?
What size resistor ?Ok, B103 is a Linear (B type) 10K pot... You would probably need to add resistors to the pot and the amp to get usable readings out of that stick.
Up loading vid shortlyBut... how does it play?
hey i'm starting a monkey ball project soon with an original gd rom set up. was this stick satisfying or did it just not work out completely?Analogue amp reproduction pcb
Purchased from arcade art shop.
Will update a vid amd review
as soon as it arrives .,
I still need to add the amp between which I will do soon amd let you knowhey i'm starting a monkey ball project soon with an original gd rom set up. was this stick satisfying or did it just not work out completely?
