Just playing again withoutHow much percentage better?
Pcb to get a feel of difference.
Got an issue at moment
Can’t seem to get both x & y working
Might need another analouge stick
yeh without amp board analogue stick is just slow ..But if you recalibrate what's the difference?
Never mind, I asked that before your second paragraph was added.
I'd be curious how that stick fares in the later levels. I'll have both sticks but Gundam stick seems like the obvious choice. From what I've read the Sega analog sticks are usable but struggle heavy on the more accurate stages.I might have my grounds and analogue
Even with the added velocity on in game options .
The amp board does work im only testing with the sega standerd analogue stick .. not dedicated monkey ball and gundam sticks which I think have diffrent pots
Does your stick reach the full range when calibrating? If so then I don't understand how quick you want it to be.Tested my analogue stick without pcb
Works fine with monkey ball but not quick/ velocity enough.
Nah ..Does your stick reach the full range when calibrating? If so then I don't understand how quick you want it to be.
The output values of the official banana stick are different. In your link to NG.com Codecrank said his didn't work at all without an amplifier. If yours is working without then maybe that's just how it is - you use the range for a gradually increasing lean, and the full extent for a full tilt.
00- ffH. ?Sure this isn't the difference between a joystick with a long throw and a joypad with a small analogue stick?
Does your arcade stick reach the full range?
na.suzohapp.com
