Dos mame , sound blaster issue
5,655CR
Why are you breaking out of autoexec.bat like this? It means the path command hasn't been set. Can't you exit ArcadeOS back to DOS?
5,655CR
I mean, if you just let it boot, you end up with arcadeOS running, right? Can't you then just exit arcadeOS back to the dos command prompt somehow? I've never used arcadeOS so don't know.
7,339CR
I can exit yes
To
C:\AOS
I cannot get to
C:\ _.
I don’t know how to ?
I tried delete and return
But it keeps it as
C:\aos
Hexen
487CR
I can exit yes
To
C:\AOS
I cannot get to
C:\ _.
But it keeps it as
C:\aos
CD.. That's CD with two dots. You will need to add something like 'CD C:\' as the last line of your autoexec to return the machine back to the C: prompt after exiting AOS.
'Change Directory, up one level'
7,339CR
Looks as though you don't have the ATTRIB command, can you get to C:\ and type in DIR/W <return> and look for a folder called DOS or anything similar, post a pic.
I will do this bud in morning
ok 1 sec
7,339CR
I have not touched these DRQ
All are disabled .
But I’m reading that these are DMA .
Set blaster=a220, irQ 5, D1 ,H5, p330, T6
H5 being the high 16 bit dma ( DRQ )
Só I need to use irQ 5
And I need to enable DRQ 5 ?
Is this correct ?
Hexen
487CR
All are disabled .
Is this correct ?
That's just the power saving settings, make sure the IRQ and DMA are set as the pics I sent earlier. (PnP./ISA I think - plug and play, industry standard architecture)
Hexen
487CR
All are disabled .
Is this correct ?
That's just the power saving settings, make sure the IRQ and DMA are set as the pics I sent earlier. (PnP/ISA I think - plug and play, industry standard architecture)
7,339CR
I have to set oporations mode extended because this is the only setting that lets me set DMA to 1
See oporatioms mode
Is this correct?
Ecp DMA channel 1
Also this ecc parity mode ?
I don’t know what this needs to be ?
