Juno first green lines
4,365CR
Green lines down the screen and text has jailbars across.
Looking at other repairs it looked like the 4116 ram so I ran @NivagSwerdna test rom but that showed all vram to be OK.
Next I thought it might be the 7489 ram but it wasn't that either. I swapped out the 083 and 083 customs from my hyper sports but that made no difference.
I've checked most of the chips around the 4116 ram but can't see anything wrong except for a damaged track coming from pin 11 of the LS367 at F11.
It doesn't appear to affect the bad graphics and even with F12 removed from the the game appears to run fine so that's not the issue.
So any ideas where else I could look.
4,365CR
All except for the one at A10.
While the jailbars though the text may have something to do with the 4116 ram I'm thinking the green lines are something else since if a 4116 ram is bad the lines are horizontal (if the monitor is set to it's normal vertical orientation) where the green lines are vertical.
4,365CR
Just tried the test rom again and saw something I missed.
The green lines appear to change as the test goes on but not in a consistent manner and disappear during the sound test for a while.
Didn't notice this during the gameplay as there's a lot going on so the test rom has helped me spot this.
I don't now think it's a ram issue as the lines are broken in a very consistent way so it's possibly some timing signal being off.
5,831CR
Sure looks like the green lines are associated with the text layer. But then the sprite going along the bottom seems to cause a line to show. Maybe a fault in the section that combines layers? Just a guess as I'm still very much a noob at this stuff.
7,573CR
are you getting good voltage for the 4116 ?
  • Shift Register/Logic Chips: ICs responsible for serializing pixel data (e.g., 74166, 74165) often fail with distinct vertical lines during display or RAM test routines. [1]
  • Multiplexers & Buffers: Components like 74LS257 or data buffers (74LS374) that route address lines to the video RAM
7,573CR
4116 rule out if games running as for cpu ram.
If the vertical lines appear everywhere on the screen and affect the text/writingwhile the game is running, you can rule out the 4116 main CPU RAM.
This behavior means the main CPU is functioning properly—it is computing game logic and actively writing data to the video layout. The issue lies entirely in the final stages of the video generation path, where character text and background elements are serialized into pixels.
On a Konami Juno First board, check these components in order:
1. The Character RAM (Most Likely)
Juno First handles screen text (scores, lives, waves) through a dedicated pair of 2114 Static RAM chips located on the video board.
  • The Fault: If one of these RAM chips has a failed internal data pin, it cannot hold stable bits for character generation. This injects constant vertical stripes directly through the text and background grid.
2114 fails
It fails to hold the characters in that
Position .. displaying random vertical lines
4,365CR
With my video probe I've found the green lines are coming from pin 13 of the 373 at E14.
When I video probe it there's solid green lines exactly where the broken green lines appear so the errant data is being mixed into DB6 somewhere.
7,573CR
Is The principle sound ?
That the issue is in the final video genaration stage .
A 74ls stuck ?
a shift register has a corrupt bit and repeating it forming the lines ?
Its drawing but drawing garbage
NivagSwerdna
806CR
The video is quite interesting...
Firstly the JUNO FIRST and the space ship along the bottom are painted by the blitter hardware... and that looks fine.
On Page 1...
STATIC OK has some bits missing and they seem to have been painted repetively elsewhere but in the wrong direction...
On Page 2...
As the checksums are rendered the more green lines occur...
When the 2nd column is painted... more green lines...
There are definitely bits missing from the checksums that then manifest themselves as green lines...
Again the blitter ship works fine until right at the end.. an extra green line... weird!
On Page 3...
You get a green line and then it disappears (as a side effect of the SFX numbering)
It comes back at SFX 08.... and interestingly the blitted ship causes a green line to appear and disappear!
Let's not blame the Konami 081 for the moment.. the interleaved DRAM timing is a nightmare...
I would be tempted to socket and swap the 74LS153s around that mux the addresses...
weird that the VRAM test works... I'm not really sure TBH
NivagSwerdna
806CR
Does the game play fine? i.e. it is just the rendering that is the problem?
I guess logically if the VRAM test passes then it must just be the VRAM to video logic?
But it dependent on the value in the VRAM... tough one. This is what we come to school for...! Good Luck!
7,573CR
Try probing outputs of the inputs
On the 74ls166 ( if it has one of these chips ) or 74LS157/74LS257
as the screen matrix is x axis horizontal as it follows the monitors raster
Faulty selecter pin on the mux
Causing it to lock up over laying in
Straight lines ..
This one maybe be intermittently locking up ( shorting internally )
