PC Problems
Vorbis
724CR
If it wasn't seated properly it wouldn't run at all would it? Games will run with all the bells and whistles, just not for very long!
Vorbis
724CR
No clue what I'm doing or what I'm supposed to run🙄, but this is what I'm seeing
ZedEx48K
8-Bit
1,409CR
Oooh, I just spotted something, the gpu on your cpu is enabled, you need to find the bios option and disable that, slim chance it may be part of your problem, either way it's not needed, and really stupid question, you have plugged your display cable into the gpu not the motherboard?
Vorbis
724CR
Yes it's plugged into the gpu
Vorbis
724CR
Surely, it would just run at whatever frame rate it can produce and just show choppy graphics.
At this point I've pretty much given up, I'll talk to their tech support tomorrow but at the very least it needs a full reinstall. I couldn't even run in safe mode as I don't seem to have use of the keyboard when I boot to advanced recovery options.
kingtreelo
19 (100%)
1,660CR
the main thing is, can you play MAME 0.194
in all seriousness, hope you get it sorted, i wouldn't go near a pre-built PC in this day and age, they are basically plug and play
mr grissom
170CR
Surely the pc had a burn in period before dispatching making sure everything was working, must had someone who thought " yeah windows is installed its fine " and threw it out the door.. have sturn words with them as you have handed over a large sum of readies to them.
ZedEx48K
8-Bit
1,409CR
Give cinebench r23 a try and see if your CPU can run it for a while or topples over, https://cinebench.net/#downloads
Also, memory wise you can disable EXPO and see if stability improves.
But yeah, I would deff be on the phone anyway, can't have tested this much!
Vorbis
724CR
Yes, not like I did anything before it started crashing other than installing Steam. Since then I've tried updating everything but it won't even let me reinstall the latest windows version and even with Steam uninstalled other installed games get fatal errors. I've reinstalled the latest drivers both from the Nvidia app and manually. I've updated everything Asus related from armoury crate but that hasn't done anything. Only thing I haven't done is completely uninstall the Nvidia drivers as I can't get into safe mode to do it 😭
