Today I did this to my cab...
AaronBoone
165CR
glstar said:
This is just great.
I need to do this for my buggy boy jr....
Could you send me pics of your cable adapters, please?
Yeah I'll try and get some pictures tomorrow. I think there are different versions of the board as the ones online look different to mine, and I know from looking at DarthNuno's thread over on DLF that the 3 screen version has a different pinout. I'll post some photos of my board too as the pinout on KLOV is wrong for mine as it confuses 2 of the connectors although I don't know if that's a typo or not.
glstar
160CR
AaronBoone said:
glstar said:
This is just great.
Really?
Maybe is for this reason why on mine cabinet i cannot understand very well why my connectors are differents from the ones i see on speed buggy manual.....
Oh god...
Some pics of your setup cold be really really useful.
Thank you very much.
Hurray Banana
2,717CR
As I had to drag my DK jr out to install DK (and move the arcade round to do so - instant sh*t tip as my missus would say) I decided to swap out the T-moulding.com nintendo flat (which isn't) for some proper flat repro t-moulding that I had sat in a box for about a year.
flat nintendo repro on the left, t-moulding true flat nintendo on the right
Installed
I also installed the new repro DK jr buttons Mike has just released
Mike's new repro on left, Mikes old nintendo buttons on right, interestingly I had to use the lock nuts from my original and fag burnt jr buttons, so the repro's have the original nintendo thread size, they are also longer matching the originals, so adjustment of switch holders necessary.
installed
Hurray Banana2016-11-20 11:59:39
AnDyC
527CR
My marquee brackets had seen better days
So sanded them off primed painted and lacquered them and fitted some leds behind the marquee glass.
AnDyC2016-12-20 22:05:58
Shinydaz
806CR
Removing old parcel tape from my mini cab.
Firstly I soaked the tape in vegetable oil for 20 minutes, then I scrapped the tape off gently with a plastic scrapper.
I then re-applied some more oil over the sticky residue for a few minutes, washed it off and rubbed it all over with hot soapy water and a magic eraser, job done, happy with the result with my £50 cab.
smarty
Ready Player One
1,290CR
I had some oomph to pick up working on my Asteroids setup for a future project. My Power Brick didn't have the 30-0-30 AC required to power the monitor so I went down the route of adding and external transformer to provide the correct voltage. The existing AC supply from the Atari Power Brick was used to power the new transformer, the output from the new transformer is then routed onto the existing cables to the monitor connector.
After that it was a case of powering up the monitor. I had to confirm the pinouts on the deflection board as the monitor is a G05 but the deflection board was a W&G V2000. The connector is keyed in a different place so I compared both sets of schematics and did the following. In the loom that plugs into the P500 connector, remove the purple cable from pin 4, sleve it up so it's insulated, it is not required, remove the 'keyed link' from pin 5 and place into the position at pin 4. The V2000 deflection will now happily work in the G05 chassis.
After completing this, I was only getting a bright dot in the centre of the display. I checked the voltages on the connectors and they all seemed good. Taking the deflection board out I noticed the two high wattage resistors at R100 & R101 looked melted/burnt/warped. measuring these with a meter they appeared open circuit, I removed them from the board and sure enough the were not giving a reading. The Vector FAQ talking of these causing problems, I temporarily replaced the resistors with some thick gauge wire, when powered up I could hear vector chatter and after a few moments the asteroids test pattern appeared on screen, after tweaking the size adjustments on the game pcb everything was looking sweet!
Next up I will be shotgunning the Deflection and HV board's to hopefully reduce downtime in the future.
RolyRetro
277CR
Nice finish, presume that was rattle cans? What did you use? I was going to get mine powder coated but fancy trying this method if it's an easy DIY job.
AnDyC
527CR
I went to my local auto paint and bought the cheapest primer/black gloss/topcoat rattle cans.
It's an easy job if you take your time, thin layers and a gentle rub in between coats, if I have time I also sand the paint job :)
RolyRetro
277CR
I had a fun day on a Saturday restoring an old BAS jamma control panel that had ripped vinyl. After cleaning and sanding down the metal panel and coating with some hammerite on the back to halt further rust, I prepared to apply the vinyl that Muddymusic lovingly recreated from the original (thanks Olly).
Slow and steady!
Populated with button and joysticks, and some nice shiny new joystick bolts
And then back into the cab for some play testing
Next up, new t-molding
